Car dies Radomly.. Horrible Misfire @ idle. Smoke out the intake Manifold
Old 11-05-2005, 11:42 AM
JDMlyfestyle's Avatar
Default Car dies Radomly.. Horrible Misfire @ idle. Smoke out the intake Manifold
well i took the car for a spin today and it just died while driving. and Hondata said it was Ignition output signal.
So i replaced
Cap
Rotor
Plugs
ICM
Coil
Started the car and the idle was a little rough as soon as i got the tiiming light out and played with the dizzy. and 2 seconds later it just died.
So i tried starting it again and it wouldnt turn over. and as soon as i stopped trying to start it there was a thud sound so i went and looked and there is a little smoke coming out of the intake manifold.
So i immediately went to Timing issue. Crank liked up with mark and i pulled the valve cover and the cams are dead on
So what the expletive is doing this? Im stumped. No more CEL and im not sure what else would cause this.
Help a brotha out
Old 11-05-2005, 12:17 PM
No one
Old 11-05-2005, 12:21 PM
dogbiscuit's Avatar
i would try but i've never heard of this.. i'm stumped as well.
Old 11-05-2005, 12:49 PM
damn is the forum just slow or is everyone stummped like me?
Old 11-05-2005, 12:52 PM
dohcMONSTER's Avatar
Default Re: (JDMlyfestyle)
bump for an answer i got nothing man sorry......
Old 11-05-2005, 01:00 PM
damnit
Old 11-05-2005, 01:44 PM
Ive called everyone i know.. called Matt from Hondata. and dave from whipfactory and they are stumped as well.
waiting on a friend to do a leakdown and compression test.
Old 11-05-2005, 01:49 PM
l337hxr's Avatar
take the car to pep boys. let them figure it out. they are after all, ASE-certified.
Old 11-05-2005, 01:57 PM
HAHAHAHAHA
NOOOOO Shop will ever touch my car.
Only to be tuned thats the only time my car will be touched by another person
INVALID's Avatar
Location: Why so you can pretend like youre interested, FL/OK
Default Re: (l337hxr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l337hxr &raquo;</TD></TR><TR><TD CLASS="quote">take the car to pep boys. let them figure it out. they are after all, ASE-certified. </TD></TR></TABLE>
Yeah, take it to Pep Boys so they can visually inspect your car. Don't take it there.
Old 11-05-2005, 02:05 PM
92civichatch1's Avatar
Default Re: (INVALID)
what color is the smoke coming out of the mani and whats it smell like. get me as much info as u can and ill see what i can do i have a few honda guys i kno.
Old 11-05-2005, 02:36 PM
it wasnt Pouring out.. But just a little smoke..
NOW The Code 15 is Back.. DAMNIT!!! what the hell could it be wires at connector are good and the wires at the ECU are good.
Old 11-05-2005, 03:44 PM
COMMON GUYS I NEED MORE HELP!
Old 11-05-2005, 04:23 PM
Luserkid's Avatar
Ive seen this happen quit a few times. A couple of reasons this happend is due to firing order (im more then sure you dont have a firing order problem) Another time i saw it the dist. was 180 (did you take off your dist anytime resently?). Another time was due to a bad compression (valve adjustment needed, usual case.)
Get a compression testor and check your numbers. If there nothing better then perfect do a valve adjustment. Or for the hell of it do one and see if that helps if you cant get a compression test.
Your throwing a code 15 and you changed out the ignitor and ignition coil? Werent you using MSD? Did you try without the MSD and a stock dist.? I would try that.
Old 11-05-2005, 04:32 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">waiting on a friend to do a leakdown and compression test.</TD></TR></TABLE>
That or a ECU problem.
Whats the voltage at A21 KOEO?
You test the acutally connectors? ECU and dizzy.
Old 11-05-2005, 08:18 PM
Leakdown was all within 3-6% going to do a valve adjustment.
THE MSD is off the car i put a new dizzy on it from advanced auto and it worked fine for this past week.
Tomorrow im going to do some inspecting on the harness
Old 11-06-2005, 01:43 PM
Completed valve Lash and it still does it and they all were within spec.
Old 11-06-2005, 01:59 PM
Default Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Completed valve Lash and it still does it and they all were within spec.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
You test the acutally connectors? ECU and dizzy.</TD></TR></TABLE>
Old 11-06-2005, 02:03 PM
ECU is Fine.. i dont remember the voltage exactly. but i was on the phone with matt from Hondata. and he said everything was fine as we were doing the voltage theck through everything.
Possible that i got a Bad Coil or ICM?
Old 11-06-2005, 02:14 PM
MugenHonda's Avatar
Location: With my POS D15B2, Whereever whenever, United States
ignitor or is that the same as the icm&gt;
Old 11-06-2005, 02:17 PM
khmboostedeh2's Avatar
Default Re: (MugenHonda)
have you pulled your plugs since u changed them and last drove it? are u getting a spark?
Old 11-06-2005, 02:29 PM
MugenHonda's Avatar
Default Re: (Jeterkm02)
check your injectors
on nissans it is common to misfire due to a bad injector
Old 11-06-2005, 02:36 PM
Its getting Fuel, Its getting spark but the spark Dies out after about 20 seconds of the car running and it dies.
Old 11-06-2005, 02:40 PM
I am a (Trial User) Army
litterbox's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Another time i saw it the dist. was 180 (did you take off your dist anytime resently?). </TD></TR></TABLE>
Old 11-06-2005, 03:07 PM
Dizzy is not 180 out..
TDC The rotor is on the #1 plug..
It runs perfectly fine for 20 seconds and stops
Quick Reply: Car dies Radomly.. Horrible Misfire @ idle. Smoke out the intake Manifold
