camber kit
camber kit
ok i bought some cheap rhino camber kits on ebay, now the ball joint on the passenger side is make noise. every little bump it makes noise as if it were loose. my question is, is there a way to fix that or do i have to replace it? if i have to replace it do i have to buy the whole thing again or can i just buy the ball joint? thx in advance
Re: camber kit (eglude)
you can buy the ball joint separately, if you can i would reccomend getting a skunk2 kit to replace the one you have, check the hondamarketplace im sure some1 has a set for cheap
Warren
14
06-07-2002 12:34 PM
