building a jdm 98 spec type r head
Old 07-15-2009, 10:06 PM
blade0314's Avatar
Default building a jdm 98 spec type r head
hey every1 i got a jdm 98 spec full itr swap and i want to get my head fully built..keep in mind that i am keeping my block fully stock and just wana build the head.... i think i wana get the following: please let me kno if these are quality parts that will yield a good hp gain
Skunk2 Pro Series DOHC adjustable came gears
Skunk2 B-series pro series B16-B18C VTEC Camshafts Stage 2
Skunk2 Pro Series B series Titanium Retainers
Skunk2 Pro B-series DOHC VTEC Dual Valve Spring Set
Greddy Timing Belt - B18C
and then i have a few choices when it comes to valves here they are:
Skunk2 B-series VTEC Forged Valve Set (STD-Comp)
Stock size. Stock compression (dished valve). 8 intake / 8 exhaust / 16 valves total.
Skunk2 B-series VTEC Forged Valve Set +0.5mm OS (STD-Comp)
+0.5mm oversized valves. Stock compression (dished valve). 8 intake / 8 exhaust / 16 valves total.
Skunk2 B-series VTEC Forged Valve Set (Hi-Comp)
Stock size. High compression (flat valve). 8 intake / 8 exhaust / 16 valves total. $291.99
Skunk2 B-series VTEC Forged Valve Set +0.5mm OS (Hi-Comp)
+0.5mm oversized valves. High compression (flat valve). 8 intake / 8 exhaust / 16 valves total.
so which valves are best for my application?
and also should i get a aftermarket intake manifold and throttle body? if so which ones are best? thanks every1 i appreciate it
also how much more horsepower does every1 think ill be making over stock ?
Old 07-15-2009, 10:20 PM
96DelSol's Avatar
Default Re: building a jdm 98 spec type r head
Why arent you building the block?
Old 07-15-2009, 10:24 PM
thumper64's Avatar
Don't get the titanium retainers unless you're planning to rebuild your top end in another 15K miles. They are made for race use only and tend to mushroom over time, resulting in dropped valves.
aftermarket springs aren't necessary, just add dual springs to the exhaust side I believe. ITRs had dual springs on one side, so just get another set of inner springs and add them to whatever side doesn't have them. If it's too expensive, then get aftermarket
Why buy an ITR head if you're just totally redoing it anyway? A mildly ported P72 head would perform just as well
Read before buying retainers. This is why I have a set of BC steel retainers for my build I'm planning, not Ti.
http://www.team-integra.net/forum/di...g+Common+Topic
Old 07-15-2009, 11:23 PM
91rexy's Avatar
Do a pro series intake manifold and throttle body with size of your choice. Im a big fan of skunk2 parts and it looks like you are to. It will give you a significant increase in the horsepower and torque ratings. Its tough to say how much horsepower you will have but those motors come with about 210. So i would say anywhere around 275hp and 175tq if you do the high compression .5 oversized valves.
Old 07-16-2009, 12:03 AM
thumper64's Avatar
ha, doubt it. a 15-20 increase from cams, maybe like 1 or 2 from the slight difference the flat top valves will make and like 5 on the top end from a higher flowing TB and intake. 65 is not realistic.
Old 07-17-2009, 12:51 PM
blade0314's Avatar
hey guys thanks for the info one of my bos is selling his type r head with the following for $2000 do you think its worth it? and what kind of hp increases do you think i can see?
Typer head
Full race port and polish done by jun in califonia
Supertech vavle train
Skunk2 stage 3 cams
Skunk2 cam gears
Golden eagle fuel rail
Rc 440 injectors
Aem regulator
B&m gauge
Jdm typer vavle cover
Flat top vavles
Skunk2 pro manifold
Skunk2 pro t/b 68 port and matched
blade0314's Avatar
and are skunk 2 stage 3 cams daily driveable?
Old 07-17-2009, 02:29 PM
91rexy's Avatar
i wouldnt put stage three cams in a daily driver. not tryin to bust ur ***** or nothin here thats just my opinion
Old 07-17-2009, 02:43 PM
fastrxu's Avatar
^^^ x2
but you can always buy somthing milder and sell the stage 3's
Old 07-17-2009, 02:50 PM
Crazy Honda Guy
Deetz's Avatar
You sure you want to rip apart a perfectly good type r head? With all the work and parts your looking into, why not do up a regular B16A (PR3) head, you'll have pretty much the same result.
tempsohc
16
12-08-2011 01:01 PM
smnowell
82
01-24-2011 11:52 PM
StolenTeg
08-14-2010 09:53 AM
xander1100
08-11-2008 10:52 PM
B6teen
07-03-2004 11:47 AM
Quick Reply: building a jdm 98 spec type r head
