Broken threads for valve cover
Old 03-11-2017, 11:54 AM
Slowbro98EX's Avatar
Default Broken threads for valve cover
We were reinstalling VC after a gasket change. Heard a snap when we were finger tightening the bolts down.
pulled cover back off to find this.
Can anything be done to repair or can it be replaced somehow?
Old 03-11-2017, 06:17 PM
Hysterically Calm
TomCat39's Avatar
Default Re: Broken threads for valve cover
The easiest repair is to have someone experienced with aluminum welding weld a new piece there that can be tapped. Then tap it to the correct thread size and pitch.
The other option is get the piece from another rocker assembly but I do believe the head will have to go to the machine shop to be worked. I do believe that also works as a cam cap too, thus the required machine shop hone to mate the piece to the head.
Old 03-13-2017, 07:33 AM
Fish Twig
tony_2018's Avatar
Get another piece.
Old 03-13-2017, 10:00 AM
joey1320's Avatar
https://honda-tech.com/forums/honda-...b16a2-3293521/
Old 03-13-2017, 04:39 PM
Hysterically Calm
TomCat39's Avatar
Hahaha.
Besides the fact OP didn't show they still had the broken off chunks.....
The D16Z6 engine here doesn't have the same kind of design that you can easily reinforce it with sheet aluminum as well as create a safety net if the broken piece fails to be held by the epoxy.
The B16A2 head has a nifty design that you can create a reinforcement trap in the event the epoxy fails.
Besides the fact that everyone thinks I'm a moron for even suggesting it even though on non cast parts JB weld held 10 pounds approximately 6 inches out from the glue point without issue. I'm not a mathematician but I do know that the leverage distance multiplies that 10 pounds to much more than 10 pounds pressure on the glue point. It failed after a few minutes of 15 lbs at the bolt tip and this was with sand blasted, non cast parts (natural cast roughness bond).
So I figured it's best to just conform and keep my personal opinions that I know work well for me to myself.
Loctite metal was a better epoxy for cold rolled 3/8 head bolts to machined aluminum bar.
Old 03-13-2017, 04:48 PM
tamboo's Avatar
lmao screw the naysayers, keep thinking outside of the box.
don't ever change to placate conventional thinkers.
Pics of my JB Weld job on a cracked block | The H.A.M.B.
Old 03-13-2017, 05:28 PM
joey1320's Avatar
Originally Posted by TomCat39
Hahaha.
https://www.youtube.com/watch?v=bM4IGweHT2k
I was actually posting the link for the different options and not just one or the other. I would do the same I recommended the B16 owner.
Old 03-13-2017, 05:42 PM
Hysterically Calm
TomCat39's Avatar
https://www.youtube.com/watch?v=NYB92jGPnlg
Old 03-13-2017, 06:19 PM
HondaTechMan121's Avatar
im sorry but unless u superman that's not finger tight But hope u can get that fixed cuz a leaking value cover just sucks
Old 03-16-2017, 02:08 PM
Icon4 Re: Broken threads for valve cover
It was finger tight. I'm assuming the shop that replaced the head gasket and water pump may have over tightened it and may have caused the issue. I just unbolted replaced gasket and tried to hand thread the bolts back In when it happened.
We have tapped into the hole bit deeper and put a threaded Rod in place of the bolt with loctite with a nut on top of the valve cover.
It holds very well, since the bolt isn't torqued much at all. Just a quarter turn past hand tightened.
Old 03-16-2017, 02:11 PM
Hysterically Calm
TomCat39's Avatar
If I recall correctly, 7 ft-lbs is spec in the FSM.
Old 03-16-2017, 02:13 PM
Our torque wrench didn't even go down that low. We had it done in inch
Old 03-23-2017, 11:26 AM
Wanted to let everyone know the outcome.
EJcharlie
04-27-2008 08:36 AM
92integraVTECgsr
08-01-2005 09:21 PM
Hybrid 350GT
08-29-2004 01:20 PM
NaVamous
07-11-2003 08:26 AM
maderfacker
08-24-2002 02:13 PM
Quick Reply: Broken threads for valve cover
