brake light recently came on and stays on, need help
Old 09-13-2011, 06:26 PM
Project94TegLs's Avatar
Icon6 brake light recently came on and stays on, need help
Hey fellas, i have a 97 Civic EX, manual, completely stock. Recently the brake light on my gauge cluster came on. Its dim but when i lift the park brake up then it shines bright as it should. My brakes are due for pads and rotors, its a little squishy. Park brake does work. There is no check engine light on. Only the brake and srs light. Srs light was on previously. Anyone ever have this problem before? The only thing that i can think of is a ground wire making connection by the park brake. Before i start taking my center console apart, i want to save my self the hassle if i dont need to take it apart. Thanks in advance, any help is appreciated.
Project94TegLs is offline
Old 09-13-2011, 08:32 PM
ej1b18c1's Avatar
Default Re: brake light recently came on and stays on, need help
check the brake fluid level and the little wires that run into the master cylinder.
ej1b18c1 is offline
Old 09-13-2011, 08:43 PM
rhymeshark916's Avatar
You just mention you are up for a brake job. There you go. Get a set of brembo blanks and autozone pads, bleed it properly and top off the fluid. You should be set. You can also adjust your parking brake and also clean of brake dust on your rear drums.
rhymeshark916 is offline
Old 09-14-2011, 01:23 AM
Technical Hero
HondaPartsHero's Avatar
Brake light comes on for 3 reasons
1. Low fluid in master cylinder (BAD)
2. Parking brake is on
3. Master cylinder fluid level switch is unplugged
HondaPartsHero is offline
Old 09-14-2011, 04:34 PM
Welp, I had a chance to get under the hood today and this is what i got so far. Brake fluid level is between max and min line so that was fine ( i did top it off), the 2 wires/plugs that connect to the cap are connected, i did disconnect and reconnect to make sure they were plugged in firmly and securely. Park brake was all the way down. Still nothing. Light stays lit. Any other ideas i can try?
Old 09-14-2011, 06:07 PM
delsolo95's Avatar
change the cap on the master cylinder reservoir. it happened to me. barrow a buddys brake master cylinder cap and see if problem persist.
delsolo95 is offline
Old 09-14-2011, 06:12 PM
delsolo95's Avatar
on second thought.
turn the car to on.
take the cap off and leave the wires plugged in.
have friend stay in the car and watch the brake light while you move the bottom of the cap up and down. when up the light should go off. when down the light should come on
Old 09-14-2011, 06:23 PM
delsolo95's Avatar
the yellow part circled should move up and down
Old 09-14-2011, 06:42 PM
R.I.P. Mark
MRGRIM's Avatar
another thing to check as this is a known fault ...Grrrr
remove the back half of the center consoul and unplug the ebrake light wire if the dash then goes out its a faulty/dirty switch
MRGRIM is offline
Old 09-27-2011, 03:57 PM
Hey guys, i was finally able to look at my car today. I had a friend move the part on the brake fluid reservoir up and down to see if there was any change....still nothing. I also took apart the rear portion of the console and disconnected the brake light switch, still stays lit dim. Im stumped now. Any other ideas guys?
Old 09-27-2011, 06:02 PM
delsolo95's Avatar
change the cap, if the results are the same, id say you have a open wire shorting it out.
Old 06-02-2015, 07:00 PM
SohcZcCrx's Avatar
I'm having the same problem. Did you ever figure it out?
SohcZcCrx is offline
Old 06-02-2015, 07:29 PM
Former User's Avatar
You bumped old threads, which are not the best place to get answers. Please create your own thread and also add car information, and any other relevant information.
Former User is offline
ismellskunk
06-04-2006 02:35 PM
xTurtle714x
11-28-2004 01:57 AM
EuRoBrO
12-01-2003 01:32 PM
civicboisi
03-08-2003 06:45 AM
Quick Reply: brake light recently came on and stays on, need help
