brake light
Old 08-29-2012, 10:51 PM
COEHR's Avatar
Default brake light
Whats up guys ive been having this problem on and off, my brake light on the cluster always stays on, its not the parking brake switch, u can tell when i engage the e-brake it gets brighter and when i release it it dims but stays on, ive had this stay like that for about a week then it turned off by it self for about a month and now its back.. it went away for like one part when i turned it on then i reached my destination and had turn the car to leave it came back again i checked my fluid it all looks ok checked for some what of a leak and nothing that i can see lmk ur opinion thanks
Old 08-29-2012, 11:00 PM
jbpnoman's Avatar
Default Re: brake light
You may have a short/cut in the wire for the switch.
Old 08-29-2012, 11:54 PM
Solster's Avatar
some hondas have a sensor for the brake fluid check that and see if it's low
Old 08-30-2012, 08:28 AM
COEHR's Avatar
i always top it off and it stays on i even disconnected the ebrake switch just to see if it was that and nothing
Old 08-30-2012, 01:27 PM
O.G. triple O.G.
NVturbo's Avatar
The wire is a negative input so it will stay ON if you don't connect it to the ebrake switch. Check your brake light bulbs.
Old 08-31-2012, 12:26 AM
COEHR's Avatar
brake bulbs are fine
Old 08-31-2012, 12:49 AM
jbpnoman's Avatar
Run the length of the wire with your fingers. Inspect it for any damage. A short in the wire can cause what you're describing.
Old 08-31-2012, 01:41 PM
COEHR's Avatar
idk if its a short why would it disappear for a good min then it will come back and stay on for a while some times its off for a long period of time then some how it will come back
Old 08-31-2012, 06:07 PM
96_coupe's Avatar
A dim red "brake" light (dim considering it gets brighter with the ebrake) sounds like a bad fluid level switch if your brake fluid is full like you said
Old 08-31-2012, 07:46 PM
jbpnoman's Avatar
Why do people always want to ask questions, then question the answers?
If the wire is stripped and shorting, it might be moving around, making contact, then losing contact with whatever it's shorting on. Wires move. It happens. That's one of the main reasons electrical problems are so hard to diagnose.
Old 08-31-2012, 09:13 PM
Oh look, I can change this
deschlong's Avatar
^ This man speaks the truth. The symptoms you are seeing are like textbook wiring short. A "short" doesn't mean "split wire" necessarily ... sometimes it's just a "bad connection". When a connection is bad .. sometimes it's good, sometimes not... very unpredictable.
Hardrock1l
Honda Civic (2001 - 2005)
04-25-2017 08:20 PM
Z20rider
11-30-2015 07:21 AM
jdmdc2boi12
Honda Motorcycles
07-18-2009 07:37 PM
jneu99Prelude
04-27-2007 11:59 PM
3 plus 1
12-02-2003 07:42 AM
Quick Reply: brake light
