brake fluid leaking help
Old 12-01-2008, 04:54 PM
niceprelude's Avatar
Default brake fluid leaking help
brake fluid leaking in the back wheel and brake light is on and brake goes all the way to the floor with no pressure.i have to use the hand brake to stop.please help
Old 12-01-2008, 04:59 PM
bsmith100's Avatar
Well you probably shouldn't drive your car until you get this worked out.
You need to find exactly where the fluid is leaking from. If it is leaking from the rear caliper then it needs to be replaced.
Old 12-01-2008, 05:01 PM
Master Detailer
98civdx's Avatar
x2
stop driving the car.
e brakes are not ment to stop the car.
Old 12-01-2008, 05:10 PM
mcyang87's Avatar
you can check your brake line running underneath your car that might be a start if this help
i was changing a flat,maybe i break the fluid line,its leaking around the lines
Old 12-01-2008, 05:13 PM
its coming from behind the rotor there is a line and its leaking ,i dont know much about car
Old 12-01-2008, 05:18 PM
The_Honda_Guy's Avatar
Have you checked to make sure the wheel cylinders aren't leaking?
Old 12-01-2008, 05:20 PM
behind the rotor is a line is kind of hard and is leaking,what is it
Old 12-01-2008, 05:21 PM
bsmith100's Avatar
Well if the leak seems to be coming from where you describe, then it could be the rubber brake hose that runs from the metal line under the car to the caliper. Those are fairly cheap and easy to change.
It could also be the caliper itself, which is still less than 100 bucks.
Old 12-01-2008, 05:24 PM
i so happy that is it,its a metal linei think i broke it i change the tire,how to change it
Old 12-01-2008, 05:27 PM
slimjimming6688's Avatar
flip the boot of the wheel cylinders...may be leaking if you got drumb brakes in the rear
Old 12-01-2008, 05:29 PM
bsmith100's Avatar
If it is leaking from a flexible rubber line that is attached to the caliper, then that is the brake hose that you are talking about. You need a new one. They are not expensive, like 25 to 30 dollars.
You could probably take your car to a shop and have them install it for you, and bleed your brake system for 100 dollars or less (including the cost of the parts).
Old 12-01-2008, 05:33 PM
ok
Old 12-01-2008, 05:36 PM
bsmith100's Avatar
These hoses are rubber from the factory. Some people will replace the rubber hoses with braided steel lines, so that could be why yours are metal.
When you replace it don't bother to get the steel braided lines, get the standard rubber hoses from a local auto parts store or repair shop.
Old 12-05-2008, 05:31 PM
bsmith100's Avatar
Hey did you ever get this figured out? What was the problem and how much did it cost you to get it fixed?
strider2
Honda CR-V & Element
05-11-2018 11:51 AM
niceprelude
12-01-2008 05:14 PM
itzyaboyzeem03
09-21-2008 05:19 AM
about:blank
05-28-2008 08:21 AM
Quick Reply: brake fluid leaking help
