Best Clutch kit 2000 Civic Si
Old 04-28-2012, 09:00 PM
Bertsch911's Avatar
Default Best Clutch kit 2000 Civic Si
i got my civic about 5 months ago. the clutch was already worn when i got the car but now its about time to change it. ive never change a clutch before and dont know where to start on buying. everywhere i look says exedy with fidanza flywheel. can someone help me please. thanks
Old 04-28-2012, 09:01 PM
Bertsch911's Avatar
Default Re: Best Clutch kit 2000 Civic Si
also whats the best weight for flywheel. its my daily driver with aem v2 intake an full greddy exhaust. thanks
Old 04-28-2012, 09:13 PM
em1_niokka's Avatar
12 lbs fidanza flywheel is what I hear alot of people getting
you can go lower tho 10, 8, 6
as for clutch exedy stage 1 all the way
but if your not looking for aftermarket and race inspired, then I would suggest itr clutch and flywheel combo
Old 04-28-2012, 09:16 PM
Master Detailer
98civdx's Avatar
A stage 1 clutch will do just fine.
It's really simple to put a clutch in these cars! Take your time and you should be just fine!
Old 04-29-2012, 04:33 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
I'd do the exedy OEM replacement for regular driving. I like it a lot better than the stage1 for DD'ing. A used OEM ITR flywheel is an awesome upgrade. It's usually cheaper than buying aftermarket, and I feel it's of higher quality. I have a couple...but I'm probably not selling yet lol. If I were to sell, I'd say around $100 each is fair. It weighs like 13LBS. Perfect for DD.
If you feel as if you're going to want a more agressive feeling clutch or are going to see track use, the exedy stage 1 is good. It does have increased pedal effort and sometimes it feels a *little* vague. But it's real nice for an organic "sport" clutch. Better than other brands for sure.
I like the stock (genuine honda/acura) ITR clutch the best. But it's expensive as you can only get it from a dealer. My ITR came with a newer factory clutch and I love it. The pedal feels almost as light as the OEM replacement exedy..but it grabs like a stage1.
There are companies on ebay selling exedy OEMs for around $120 shipped. They also carry clutch/flywheel packages.
Old 04-29-2012, 07:03 AM
Bertsch911's Avatar
the only combos i can find on ebay are for the exedy oem cxlutch kit with a fidanze 7.5lb flywheel. or a f1 racing 9.5 flywheeel. is heavier flywheel better?
Old 04-29-2012, 07:22 AM
Bertsch911's Avatar
also i found one with a 12lbs flywheel. can someome please explain to me what the weight in the flywheel does becasuse i have no idea about it. thanks
Old 04-29-2012, 07:25 AM
Bertsch911's Avatar
yeah its just my dd i mean i do like to get on it and mess with people on the highway but its not like im a full out street racer lol. but sorry what is "itr"?
Old 04-29-2012, 08:01 AM
Bix VT's Avatar
Integra Type-R
Old 04-29-2012, 09:21 AM
Bertsch911's Avatar
What would u guys say would be the best flywheel weight for me. Its my dd an I do a lot of city driving. Thanks
Old 04-29-2012, 09:30 AM
The Grumpiest
grumblemarc's Avatar
I've been told a lighter flywheel makes the car more responsive. A 12 pounder might be fine but not really necessary. Don't go too light though as I understand you will have difficulty while in first gear. As for clutches a stock replacement from Exedy will be fine. Don't go by stages. Go by the rated torque that the clutch will hold.
Old 04-29-2012, 09:51 AM
slikz714's Avatar
oem exedy!
Old 04-29-2012, 10:01 AM
The Survivor's Avatar
The flywheel keeps the inertia of the motor going. I recommend a oem flywheel. Lightened flywheels kill the daily drivablility of any car. Say for instance if you take a flywheel off of a diesel it will not run because there is nothing to keep the inertia going. I recommend exedy clutches and despise spec clutches. I have a 2 puck spec in my z06 and it has given me nothing but problems. It really depends what you're after. I've driven all stock itr's and I love the clutch pedal and the responsiveness. It's personal preference and I hope this helped you some.
Old 04-29-2012, 10:47 AM
Zeusfire69's Avatar
GREAT advice!! ALWAYS go buy the torque rating....every brand has there own version of "stages".
As for what clutch to use....unless you are making quite a bit more power than stock...the factory clutch is great.(exedy is the factory supplier, if you went to the dealer to have it done, this is what they would use) BTW, I sold nothing but clutches and turned flywheels for almost 10years, so I've seen just about everything.
I personally like a slightly lighter than stock flywheel, mabe a 12 lbs or so. If you go any lighter, you will sacrifice some draiviablity. The 12 is a great compromise.
As for flywheels, I would stay away from anything that is aluminum with a steel "insert"...the steel and the alumunim don't expand and contract at the same rate when they heat cycle. I have seen many of these come apart because of this. Stick to a factory, or type r, or if you do go aftermarket get a stainless lightened flywheel.
Old 04-29-2012, 11:41 AM
Bertsch911's Avatar
Thank you guys for the awesome advice! You guys are great help. Here another question. I can tell my clutch is gettin bad so of coarse I'm going to get a new clutch. But I thought if I had it all out I might as well get a new flywheel. You think it would be ok to just keep my stock flywheel an a oem exedy clutch kit. My car has 114k miles on it. Keep the stock flywheel or get a new one
Old 04-29-2012, 11:55 AM
The Grumpiest
Have someone check it to see if it needs resurfacing.
Old 04-29-2012, 12:08 PM
Zeusfire69's Avatar
You should ALWAYS resurface your flywheel when replacing your clutch. Why would you take all that crap apart just to take the chance on clutch chatter? If you are using your stock flywheel, just do it right! It usually only costs about 30 bucks to resurface your flywheel...anyone who wants more is ripping you off...
Old 04-29-2012, 12:17 PM
Bertsch911's Avatar
well i was going to put the clutch in myself so i wouldne know if it needs resurfacing when i take it off as ive never done this before
Old 04-29-2012, 12:41 PM
Seagull Management
94EG8's Avatar
OEM Honda/Acura clutches are almost always made by Exedy, a few of them are made by FCC. An OEM Exedy or FCC clutch you buy on ebay is exactly the same thing you get when you buy one at your local Honda/Acura dealer, but for a lot less money.
Old 04-29-2012, 03:37 PM
Bertsch911's Avatar
so just get my stock flywheel resurfaced and go with exedy oem clutch kit? or get a different flywheel
Old 04-29-2012, 03:53 PM
Zeusfire69's Avatar
It's up to you....if the car is a daily driver, yes. You can go with a little bit lighter flywheel but it really doesn't do much. Unless you plan on boosting it or some other upgrade that is going to add ALOT of power. Just stay with stock. I ran low 13's before I even started to pull the through the stock clutch.
Old 04-29-2012, 04:09 PM
Bertsch911's Avatar
thank you for your guys help i appreciate it
Old 04-29-2012, 04:13 PM
Seagull Management
94EG8's Avatar
Generally speaking when running boost you want a heavy stock flywheel. If you were talking about the clutch, then yes, stock clutch unless a stock clutch wont hold the power you're making.
Old 04-29-2012, 05:14 PM
2000-em1's Avatar
I have the same car and I just did mine a few months ago. I went with competition stage 2 with a competition ultra light flywheel. It sucked at first when it came to breaking it in but man now that it is I'm extremely satisfied with it! It's not too tough on pressure, feels just like oem and that flywheel is the bomb! Immediately you'll feel a huge difference in acceleration and response. It's like I took a big load off the engine
Old 04-30-2012, 04:09 AM
DelSol-B18's Avatar
I have a b16a2 that I'm about to swap in my sol an I went with 9.5lb flywheel and exedy oem clutch and it's my daily
Quick Reply: Best Clutch kit 2000 Civic Si
