MSD set up help!!!
Old 02-06-2012, 03:54 PM
JDM_CAM's Avatar
Default MSD set up help!!!
wattup guys, so today i was lookin for a dizzy for my gsr, and my boy has one with the msd blaster. its complete with 8.5 mm wires and obviously the blaster. it didnt comewith the big box thing tho that im use to seeing.
how do i install this. he says its ready to go but i dont have the box thing.
am i missing anything or is my boy right and its ready to go?
Old 02-06-2012, 04:29 PM
hannslebo's Avatar
Default Re: MSD set up help!!!
I don't think you HAVE to have it...but I would just go ahead and get it anyways...you can get them for like 150 on ebay....
What it does...
Converts your single spark distributor , to a multi- spark distributor. In other words each time your distributor sends an electrical pulse to the spark plug, the msd box creates several pulses instead of one to that sparkplug, which causes a more efficient burn in the cylinder, which in turn gives you more power. My recommendation would be to go with a msd 6AL as this box has a rev limiter in it with interchangeable chips that control max rpms.
Old 02-06-2012, 05:46 PM
apexi_rsx's Avatar
with what he has you can install that without a box. the SCI or 6AL boxes are a totally different ignition set up. the blaster coil is just a stronger coil then stock. MSD's website has the instructions on how to install the. they are very easy to install. u remove ur old internal coil from inside the distributor + and -. then run those wires to the blaster coil very simple....
Old 02-06-2012, 06:06 PM
vartok's Avatar
Its the MSD setup really that nnesacary? I was under the understanding that these stock honda ignitions were good upto 400-500HP... i could be wrong though, Im still learning and just wanted more info
Old 02-06-2012, 06:14 PM
apexi_rsx's Avatar
stock ignition can do near 300hp yes its overkill for most n/a hondas
Old 02-06-2012, 06:15 PM
The Grumpiest
grumblemarc's Avatar
You're correct. It's for show unless you're running anything less than that or running some forced induction.
Old 02-06-2012, 06:22 PM
JDM_CAM's Avatar
alright cool, thanks guys.
Old 02-07-2012, 09:26 PM
techmage916's Avatar
i just got a good deal on msd stuff, got it half installed. if it is not raining tomorrow i will finish the install. you need msd's rotor and cap on a d16z6 so you have the additional hookup for the coil. you have to uninstall the stock coil pack too though... its on the dizzy.
Old 02-21-2012, 03:22 PM
JDM_CAM's Avatar
i have all that already, i have the dizzy with rotor. cap. blaster all the wires etc... it literally came off his running car. i just wanna know how to install it. is it like installing a normal dizzy?. what do i do with the blaster? just leave it hanging somewhere?
Old 03-01-2012, 10:01 AM
i used a coil bracket and bolted it in where the stock airbox used to bolt in. my coil is like 6 inches from my dizzy and its nipple is pointed right at it. btw i got it all installed the way the instructions say and it doesnt work. need to test the coil out and troubleshoot it with msd. called them and the only guy that knows anything about honda was out. that was weeks ago and he still has not returned my call.
i should note though that my install is a little more indepth. i'm adding a msd 5200 to the equation not just the blaster coil, cap, and rotor.
Old 03-01-2012, 10:40 AM
Master Detailer
98civdx's Avatar
If you have ask, you shouldn't be touching the car. Remove the old one, install the new one.
Don't forget you will need to set the ignition timing.
Don't leave the blaster hanging, that is a ****ing hack.
Seems you like throwing money away.
Old 03-18-2012, 09:11 PM
JDM_CAM's Avatar
no sh@t *** clown, dont worry about what i do with my money
Old 03-18-2012, 11:29 PM
jbpnoman's Avatar
Someone is obviously spending money on an internet connection for you to use. 5 seconds on Google will give you an install write-up for the MSD systems. I'd bet with 15 seconds of searching, you can even find the install instructions straight from MSD!
MugenSpeclNY
05-04-2012 11:18 PM
jetspeedz
06-24-2010 05:23 PM
greentegsandspam
06-12-2005 02:54 PM
d16rice
12
03-23-2005 03:41 PM
Quick Reply: MSD set up help!!!
