battery light - searched
Old 06-22-2004, 06:46 PM
mjrage's Avatar
Default battery light - searched
I searched on the battery light being on. Which is basically the charging light.
Seem to be a lot of conflicting posts... who woulda thought...?!
My battery light wont go out, I replaced the battery just to be on the safe side and still no dice.
I understand that it could be a bad alternator, my question is, to test it, do I have to have it out of the car? Can I remove/install an alternator with the motor in without any problems?
Old 06-22-2004, 06:51 PM
TrickHonda98's Avatar
Default Re: battery light - searched (mjrage)
best thing i'd say to do is run for any codes.
New User
Mr. Choi's Avatar
to test your alternator on the car do this.
start your car then remove the battery cable from the negative side. if your car runs then the alternator is ok. if it dies its your alt.
when the batt light comes on its the alternator.
Old 06-22-2004, 06:59 PM
StrikerX's Avatar
Default Re: battery light - searched (Mr. Choi)
take it to autozone or hi lo they can test it while its in your car. but the above method works great aswell.
Old 06-22-2004, 08:10 PM
mjrage's Avatar
Default Re: battery light - searched (StrikerX)
Thanks for all your posted, I will try the alternator test right now!
mjrage's Avatar
Default Re: battery light - searched (TrickHonda98)
coming up just cel 6 / 41, the ect is cracked, and the o2 is nothing to really worry me.
The SRS light also does not turn off.
Old 06-22-2004, 08:22 PM
mjrage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Choi &raquo;</TD></TR><TR><TD CLASS="quote">to test your alternator on the car do this.
when the batt light comes on its the alternator.</TD></TR></TABLE>
The car sputted as I started unscrewing the negative wire from the car(not the terminal) then died as soon as it was completely off.
I take it I need a new alternator huh?
Anyone have an OBD1 alternator for a jdm b16a SirII?
I believe only the dizzy/injectors are changed to obd2 since its in an obd2 car.
Old 06-22-2004, 08:46 PM
StrikerX's Avatar
I wouldn't buy an alternator from someone other than a parts shop. I had a prob with a new alternator not working, got another that didn't work, 3rd one was tested at the store before i purchased it and it failed. 4th time was the charm though.
Old 06-24-2004, 06:05 PM
New User
Mr. Choi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mjrage &raquo;</TD></TR><TR><TD CLASS="quote">
I believe only the dizzy/injectors are changed to obd2 since its in an obd2 car.</TD></TR></TABLE>
yes new alternator. or reman.
legionbuck
03-31-2013 04:51 AM
jxhxb
06-10-2009 01:35 PM
pendejon
10
04-27-2006 01:22 PM
Quick Reply: battery light - searched
