B18C piston rings?!
B18C piston rings?!
hey i was wondering if the JDM GSR B18C (non-type-r) piston rings are the same as the USDM B18C1 GSR?
im going to be re-ringing a JDM GSR. thanks guys.
Crazy Honda Guy
Re: B18C piston rings?!
LOL, i hope you don't think that the jdm 81mm piston rings are different than usdm ones
They come in two sizes, oem 81mm, and oversize for bored cylinders
^^Okay so i can order the ring set for USDM B16/GSR and use em for the JDM GSR right lol. all same part number that's why/same bore?
*edit*
dammit this question was kind of retarted now that i re-read it. thanks anyway.
*edit*
Crazy Honda Guy
btw, the jdm gsr has unique pistons as far as compression goes. Stock with a gsr head (P72) compression is the same as the usdm ITR at 10.6:1 compression. With a PR3 head, compression would be down to 10.5:1.......it is very very close to a usdm ITR (P73) piston
yeah i knew the pistons would yield higher compression than the USDM GSR. if i get it, this block will be used with my B16 head. thanks guys
All B series 1.6-1.8 use the same rings. That is assuming you have normal pistons that use 1.0 1.2 2.8mm thickness rings. But a set of rings for a b16 should fit a b18 LS and a B18 VTEC or a B17. All the same... Pistons too, they're interchangeable. SRP or others may sell pistons as being for a B16, 17 or 18, but they'll work on any motor.
alx_90ef
09-26-2010 04:47 PM
