B18 Swap revs to redline when started
Old 02-21-2017, 07:41 AM
92hxEG's Avatar
Default B18 Swap revs to redline when started
Hi guys I'm new to Hondas I just installed a b18 swap into a 92 EG everything is plugged in the right place but as soon as I start the car it wants to redline any idea why this is happening? I already checked the TPS I had my brother start the car while I was looking at the throttle body it was closed so idk why it wants to shoot through the roof.
Old 02-21-2017, 09:33 AM
Zack1's Avatar
Default Re: PLEASE HELP!!!
Did you check all the vaccum lines iacv stuck open anything like that
Old 02-21-2017, 03:18 PM
I like the tuna here
DumpdEJ6's Avatar
Vacuum leak, guaranteed.
Old 02-21-2017, 04:38 PM
efhatchbackracer's Avatar
My buddy had this issue and he had the map and tps plugs switched, make sure they are plugged in the right sensor and not switched or it will definitely rev to the moon!
Old 02-22-2017, 06:17 AM
92hxEG's Avatar
Thanks I'll check that.
Old 02-22-2017, 04:09 PM
92hxEG's Avatar
Default Re: B18 Swap revs to redline when started
The length of the wires were really tight to switch so I'm pretty sure they were right how I had them but I tried it and the same thing happened
Old 02-22-2017, 04:23 PM
-Intl Steve Krew
Caoboy's Avatar
Did you over tighten the throttle cable?
Old 02-22-2017, 05:56 PM
92hxEG's Avatar
No the throttle body is fully closed.
Old 02-22-2017, 06:14 PM
m90polk1's Avatar
Did you at any point change, remove TPS and then reinstall it. If the internal arm on the TPS doesn't line up within the holder slot for the throttle body plate it will cause this condition. The TPS is the only thing that dictates to the ecu what angle the throttle is at causing the described redline condition. If map and TPS are swapped it would go into limp mode not redline, vacuum leak would cause idle to hunt up and down.
Old 02-22-2017, 06:17 PM
m90polk1's Avatar
Also you said it was a swap so TPS could have been changed by previous owner. Make sure they didn't put a TPS from a sohc with the flat intake. They are easy to come by but don't work with vertical intake on b&d and can cause this issue too.
Old 02-22-2017, 06:32 PM
92hxEG's Avatar
I actually removed the TPS had to cut groves into it to unscrew it and I put a new one on still does the same thing.
Old 02-22-2017, 06:36 PM
Fish Twig
tony_2018's Avatar
If you have to cut anything than something isn't right.
Old 02-22-2017, 06:40 PM
m90polk1's Avatar
so you either don't have the arm of the TPS lined up in-between the place holder for it on the throttle plate or the place holder has one of stops bent.
Old 02-22-2017, 06:44 PM
-Intl Steve Krew
Caoboy's Avatar
probably cut into the rivet screws to remove the TPS.
Old 02-23-2017, 03:23 PM
crazyhorse2011's Avatar
So OP does your computer show a check engine code of any sort? Surely in this instance something is plugged in incorrectly, you could resolve this quicker by checking the memory bank for a stored code.
Old 02-23-2017, 04:15 PM
mk378's Avatar
The only way it can rev that high with the throttle plate closed is for something to let a lot of air into the engine, via a path other than the throttle plate.
Old 02-23-2017, 04:43 PM
Fish Twig
tony_2018's Avatar
True, the tps would just dump fuel in there and it would start spitting out fuel. Since the only entry for air is through the intake manifold op needs to get up on that and investigate.
Old 02-24-2017, 02:51 AM
m90polk1's Avatar
A TPS that is installed wrong or faulty would cause this. The TPS controls throttle response, even with throttle plate closed if it is faulty or incorrectly installed it can go to redline. Don't believe me try doing it for yourself and you will see, the iacv and the throttle plate are not fully closed at idle air is still getting in. What else in the vehicle controls throttle or engine speed????? Nothing but TPS.
Old 02-24-2017, 04:19 AM
DumpdEJ6's Avatar
There just isn't enough air to sustain a rev limit RPM without a significant air leak. I'm not saying his TPS is installed correctly, but the car is not going to redline without air, and if the throttle body is indeed closed, there has to be a vacuum leak somewhere on the intake manifold or TB.
Old 02-24-2017, 05:52 AM
mk378's Avatar
This is a big leak like having parts that simply don't mate up (TB to IM, IM to head, etc), or the brake booster hose not connected at all.
Old 02-26-2017, 08:34 AM
92hxEG's Avatar
Thank you everyone I guess I'll start trouble shooting everything you suggested.
Old 02-26-2017, 08:52 AM
Fish Twig
tony_2018's Avatar
OP you just need to look over your work, you're not giving enough details and we're not there to see for ourselves wtf is missing, incorrect or wrong.
92hxEG
02-21-2017 02:31 PM
run for cover
04-30-2012 07:43 AM
nolicense526
05-07-2008 07:35 AM
cokinut
07-18-2004 05:29 PM
Quick Reply: B18 Swap revs to redline when started
