B16 water pump vs GSR water pump... same?
Old 05-03-2003, 07:49 PM
built562's Avatar
Default B16 water pump vs GSR water pump... same?
im building an ls/vtec and i know to use a gsr water pump and timing belt. today i did a test fit of a b16 water pump on the LS block and it fits, perfectly.
anybody have a pic of them side by side, i dont own a gsr water pump yet.
Are they the same? the b16 pump fits on the integra block and the teeth fit the timing belt, so im thinking it will work
Old 05-03-2003, 08:01 PM
IM ALL BOB's Avatar
Default Re: B16 water pump vs GSR water pump... same? (akumaracer)
how many teeth does the B16 water pump have 19 or 21? if it has 21 I believe you use a gsr timing belt.. if it has 19teeth then use the LS timing belt.. I have the most horrid headache right now.. so I might be wrong.. do a search there are tons of posts on differences between the water pumps..be it LS/B16/B18
Old 05-04-2003, 11:05 AM
built562's Avatar
Default Re: B16 water pump vs GSR water pump... same? (IM ALL BOB)
i did a search and read so long threads about the physics of each water pump with 17 and 22 teeth and it was very informitive. but my basic question is are ALL vtec water pumps the same b16/b18c.
anyone?
Old 05-04-2003, 12:00 PM
sshaikh01's Avatar
I believe they're different
Old 05-04-2003, 12:01 PM
sshaikh01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akumaracer &raquo;</TD></TR><TR><TD CLASS="quote">im building an ls/vtec and i know to use a gsr water pump and timing belt. today i did a test fit of a b16 water pump on the LS block and it fits, perfectly.
Are they the same? the b16 pump fits on the integra block and the teeth fit the timing belt, so im thinking it will work</TD></TR></TABLE>
You can use any Vtec water pump and timing belt, i don't think it has to be a GSR.
unless maybe if you have a gsr head.
I'm sure i'll get corrected if i'm wrong
Old 05-04-2003, 07:21 PM
built562's Avatar
Default Re: B16 water pump vs GSR water pump... same? (sshaikh01)
does anyone have confirmation for sure if they are different, the b16 bolts on to the ls block. i have read all the threads and they just classify vtec and non-vtec and im just looking for confirmation
Old 05-04-2003, 07:27 PM
smnowell's Avatar
the LS water pump gear is stamped with 19T on it. the GSR one is stamped with 22T (pretty sure). As far as the B16 one goes, I am not positive. Just get a GSR and be on the safe side
Andrewvtec
01-21-2011 12:23 PM
cincyb20ek
05-05-2010 04:51 PM
hitvtecgetloud09
14
07-12-2005 06:43 AM
hitvtecgetloud09
07-10-2005 05:07 PM
untitled
07-25-2003 11:51 AM
Quick Reply: B16 water pump vs GSR water pump... same?
