ABS Light Problem w/GSR Cluster in EK
Old 11-04-2004, 07:22 AM
Prod's Avatar
Default ABS Light Problem w/GSR Cluster in EK
Searched and didn't find anything relevant.
I tried to reset the abs light via the procedure in the helms, doesn't work. I can't get a code either.
Here's my question, my civic DX cluster doesn't even have an ABS light first off. Now that I have the GSR cluster is this ABS light going to stay on forever ? Is it just all messed up because I don't have ABS (seeing as how I can't reset it).
I suppose I could just unplug the clip from the gauge harness but I'm trying to figure out if it's actually on for a reason right now...anyone know ?
Old 11-04-2004, 07:26 AM
racecarpete's Avatar
Default Re: ABS Light Problem w/GSR Cluster in EK (Prod)
sounds like you have it pinned incorrectly, i don't have abs and I have a gsr cluster in my 6th gen with no problems.
Old 11-04-2004, 07:27 AM
b20vtecEK's Avatar
Id imagin its throwing the light because the ABS isnt even there, just take the bulb out.
**EDIT** or yea what he said ^^^^^^^^^^
Old 11-04-2004, 07:42 AM
Prod's Avatar
Default Re: ABS Light Problem w/GSR Cluster in EK (SilverCivic2k)
so you're guys abs light never comes on for anything ?
if so screw it then, I was pretty sure everything is pinned right...I'll double check and if not then it's getting disconnected
thanks
Old 11-04-2004, 03:09 PM
BlueIntegraBoy's Avatar
You have it pinned in the wrong spot. I put a GSR cluster in my friend's 99 Civic EX (without ABS) and everything was functional. No unneccessary lights.
Alcatrax30
Honda Civic (2006 - 2015)
03-10-2016 02:57 PM
stangman39
10-14-2008 06:33 PM
EM199dcs
01-25-2007 10:58 AM
JimmyAtlantis
12-08-2005 08:51 AM
Beezle
05-24-2005 10:01 PM
Quick Reply: ABS Light Problem w/GSR Cluster in EK
