99 Ek wont start. Help plz
Old 05-06-2012, 11:26 AM
SOLFOOD94's Avatar
Default 99 Ek wont start. Help plz
Drove the car fine this morning. Was cleaning up the engine bay for a few hours went to statr it and nothing happened. I can hear the fuel pump running and thestereo turns on. Jumped the starter solenoid to the large starter wire and it just turns over dont not start up. I hear a clicking when im turning over the key and thats it. Any help
Old 05-06-2012, 11:41 AM
EK9
Dc4LsTeG's Avatar
Default Re: 99 Ek wont start. Help plz
Check for water in your spark plug holes and distributor
Old 05-06-2012, 12:16 PM
SOLFOOD94's Avatar
Checked for that. None there
Old 05-06-2012, 12:18 PM
EK9
Dc4LsTeG's Avatar
Are you sure theres none on the spark plugs? While cleaning did you remove or mess with anything? Check your engine grounds
Old 05-06-2012, 01:01 PM
SOLFOOD94's Avatar
I just found out that the #31 fuse is getting no power to it. I cleaned the battery ground and reattached it thats it.
Old 05-06-2012, 03:30 PM
slikz714's Avatar
Distributor?? Receiving any spark?? ignition module, ignition coil??
Could be the ignition rotor inside your distributor. if it is the ignition module, you should see a change of color (small circleish spot) behind/on the piece!
Old 05-06-2012, 04:20 PM
Guateracer1's Avatar
Check the grounds too the one that is next to thermostat housing that one gives huge problems sometimes...
Old 05-06-2012, 05:49 PM
SOLFOOD94's Avatar
I think i narrowed it down to the ecu being shorted. I checked the main relay all seems good but i have no pwer to the fuse # 31 not haviong power thus not letting the engine start due to power to the ecu. Picking up a ecu tomorow hopefully this works
1994turbocivic
02-10-2011 06:26 PM
jonnybadboi9
03-14-2007 06:17 PM
GQ Cowboy
12-14-2003 09:55 PM
dsmith817
11-02-2002 07:17 AM
HYBRIDGSiR
11-23-2001 07:32 AM
Quick Reply: 99 Ek wont start. Help plz
