wierd steering noise??
Old 02-16-2013, 05:15 PM
swizz977's Avatar
Default wierd steering noise??
the noise is hard to describe kinda like a rubbing everytime the wheel spins if i go fast the noise gets faster slow it gets slower like rub rub rub faster slower coming from the front somewhere when i turn a little i can hear it more sometimes or when i accelerate and desellerate i can hear it better but if i hit the clutch it kinda goes away
Old 02-16-2013, 05:30 PM
Doed's Avatar
Default Re: wierd steering noise??
is your car lowered?? reason for asking -- i had that same problem, turns out it was my wheel bearings got those replaced along with inner/outer tie rods and cv shafts might want to check that out
Old 02-16-2013, 07:37 PM
swizz977's Avatar
but it doesnt sound like a wherl bearing its not that loud and i can kinda feel it too
Old 02-17-2013, 04:36 AM
ameer_vtec99's Avatar
does your steering look hard to turn or normal ?
i just had this issue 5 days back noise sound when i accelerate its increasing
first step remove you steering belt and start the car if its same noise its because of the idler pulley bearing .just buy an oem bearing remove the old one and install the new one be careful when you install it. it should fit with out losing balance
Old 02-17-2013, 04:42 AM
t i accelerate and desellerate i can hear it better but if i hit the clutch it kinda goes away
sounds like release bearing but it shouldn't increasing when you accelerating and the sound of the release bearing like a whistle .
Old 02-17-2013, 05:41 AM
belairbrian's Avatar
what car?
do you have power steering?
does it make the noise only when moving or can you duplicate it sitting still?
Old 02-17-2013, 05:58 AM
swizz977's Avatar
only when moving accelerating/decelerating going straight too but sometimes if i turn a little the noise changes
swizz977's Avatar
92 civic lowered
Old 02-17-2013, 02:17 PM
swizz977's Avatar
anyone ????
Old 02-17-2013, 03:20 PM
StraussBuster's Avatar
Alignment? Not sure
Old 02-17-2013, 05:10 PM
swizz977's Avatar
trying to see if anyone knows what this noise is it only happens when accelerating and deselerating.. sounds like somthing crunching around and around from the front
Old 02-18-2013, 03:39 AM
camber ? could be
Old 02-18-2013, 04:16 AM
The Grumpiest
grumblemarc's Avatar
Hardly. It goes away when he clutches in.
Old 02-18-2013, 04:50 AM
swizz977's Avatar
im not sure if it goes away when i push the clutch but its not as loud.. mostly accelerating/deselerating.. when i move the wheel the sound sometimes gets worse
Old 02-18-2013, 05:38 AM
The Grumpiest
Bearing or axle.
Old 02-18-2013, 07:49 AM
Doed's Avatar
Your best bet is bringing it to a tire shop and have them check it out professionally
Old 02-18-2013, 02:11 PM
swizz977's Avatar
thanks for the help ill try to get it on a lift!!
Old 02-21-2013, 11:01 AM
swizz977's Avatar
i think it has somthing to do with lowering my car cuz thats when it started
Old 02-21-2013, 11:03 AM
The Grumpiest
Axles binding. Raise the car up then.
Old 02-21-2013, 11:19 AM
swizz977's Avatar
it doesnt click on turns tho..
Old 02-21-2013, 01:04 PM
The Grumpiest
So? What's your point? You just said it didn't do it before you lowered it. You JUST answered your own question.
Old 02-21-2013, 01:26 PM
swizz977's Avatar
so it has to be the axles if it made that noise after i lowered it??
Old 02-21-2013, 01:27 PM
The Grumpiest
I'm guessing that you didn't put the car on a lift like you claimed. How about actually getting under the car and looking instead of probing for magic answers?
Old 02-21-2013, 01:45 PM
swizz977's Avatar
will do thanks
Forrest04
Honda CR-V & Element
04-16-2014 11:50 AM
D7_62
11
12-12-2010 07:22 PM
Quick Reply: wierd steering noise??
