Transmission: How screwed am I?
Old 01-06-2014, 08:38 AM
marcelosm's Avatar
Default Transmission: How screwed am I?
I decided that today would be a good day to change the transmission fluid on my 93 Del Sol since I had no idea when the previous owner had done it.. Once I got down there though I noticed something that really freaked me out.
Now it doesn't take a genius to figure out something is missing there. The car runs great and I haven't really had any transmission issues I can think of. How bad is this? I know I would need to put it on but is the whole transmission screwed?
Old 01-06-2014, 08:43 AM
B_Swapped93's Avatar
Default Re: Transmission: How screwed am I?
it's just a dust cover I've had mine off with no issues, not on my dd tho just find a new one and bolt it up. gives me a good idea if the RMS is leaking thus I've left it off on my integra but if your car see's deep snow etc I'd want it on.
Old 01-06-2014, 08:44 AM
marcelosm's Avatar
Does it mean that fluid is all empty though? Is it as simple as bolting on? I don't have to remove anything?
Old 01-06-2014, 08:45 AM
lol no it's not near the bell housing with the internals, nope just get the bolts and plate off a scrap car
Old 01-06-2014, 08:51 AM
datsol94's Avatar
The car will live. It won't leak unless your seals are bad. The part your missing is the flywheel inspection cover. Check a local scrapyard or poke around online for one they should be cheap. If you daily the car you def wanna put it on there because it will prevent water, rocks, road debris, etc. from getting into the clutch assembly. Its mostly preventative.
Old 01-06-2014, 09:15 AM
purgat0ry's Avatar
You ... may want to find your intense oil leak though, holy crap.
Old 01-06-2014, 09:26 AM
marcelosm's Avatar
The oil leak was taken care of a while ago I just never got around to cleaning it all up again lol. Thanks for the help guys. I sort of freaked when I saw that I could see into the transmission
Old 01-06-2014, 09:52 AM
ElswickB22's Avatar
Spray some brake cleaner down there. dirty dirty dirty!
Old 01-06-2014, 10:43 AM
Hysterically Calm
TomCat39's Avatar
Also FYI. The inspection plate uses the second to last oil pan bolts on the front and back. If I recall correctly, it's 5 or 6 bolt total, you need the three or four outer larger bolts with the plate and just reuse the two bolts on the oil pan. Don't over torque them though, if I recall it's 7 ft-lbs for the oil pan bolts. ( I did mine to 10 being that's the lowest setting I could get. ), and the larger bolts I think are either 12 or 14 ft-lbs. Maybe 17... I don't remember off hand. It's the oil pan bolts you have to be concerned with though more than anything.
Old 01-06-2014, 11:04 AM
marcelosm's Avatar
Thanks a lot for the info. I'm gonna look around to find one of those as soon as it gets a bit warmer.
Old 01-08-2014, 01:14 PM
Seagull Management
94EG8's Avatar
They do, '96 - '00 are a little different and don't use the oil pan studs.
Brand new these are less than $19 from majestic Honda, expect to pay around $27 at your local Honda dealer. Part number: 21350-PR1-030
Old 01-15-2014, 04:48 PM
marcelosm's Avatar
Sorry to bring this up again but I am buying a whole bunch of stuff from majestic and I had a question. I'm not sure this is the original tranny. Is it interchangeable with other transmissions?
Old 01-15-2014, 04:52 PM
yes all d-series 5mt trans share the same plate and many other components. you're fine.
Old 01-15-2014, 04:54 PM
marcelosm's Avatar
Thanks! I just wanna make sure I order everything I need at once so I don't get raped by shipping and handling.
Old 01-15-2014, 05:01 PM
I never narc'd on nobody!
NotARaCist's Avatar
Very minor correction - all D series transmissions up to 2000 are the same externally. An 01-04 (05?) transmission and parts won't quite work.
The94delslow
Transmission & Drivetrain
01-01-2019 09:10 AM
vtec.dc2
12-08-2015 02:53 AM
jmai86
07-06-2012 03:39 PM
Shaggibus
11-14-2010 05:46 AM
imitati0n
05-23-2004 11:01 PM
Quick Reply: Transmission: How screwed am I?
