97 civic will not start have checked pretty much everything in the book but this is my first OBD2 sw
OK first off here is the build
97 Civic HX with HX wiring harness
OBD1 B18b1 long block all stock internals
ys1 tranny with avid hydro to cable swap mount
OBD2A p75 ECU
now i will list what we have checked and what we have tryed
checked all grounds using a multi-meter for both resistance and voltage drops and all were reading a solid 12.3 Volts which is exactly what the battery itself is putting out
have tryed multiple sets of injectors (although it seems fuel is definently the issue with this build
One thing we DON'T have the2 of the sensors plugged in CPS or the FIA(not sure if FIA is the right term for it but its the plug that comes out of the injector area on the harness looks like it could be for a 5th injector but goes to that sensor which we dont have a place to plug in on a OBD1 LS intake mani .
We have tested all grounds going to the ECU and again all read 12.3 volts just the same as the battery
Have tryed 2 different dizzys one OBD2 one OBD1(had to re pin it)
Have tryed 2 different ECUs stock 97 HX and the OBD2 P75
have quintuple checked firing order and is definently correct
Fuel pressure seems to begood but havent actually tested the pressure reading on it
tryed open header thinking the cat may have been cloged
tryed 2 different MAP sensors
And it does get consistant spark on all cylinders
getting roughly 160-180 PSI compression 1-4
OK heres what the car does when trying to start it
it will start with starter fluid which tells me its a fuel issue for sure
BUT! once you get it started with starter fluid you can keep it running by tapping quickly the gas between 10-20% throttle
once it says started it will throw a CEL but im unable to check that til i can get a code reader tomorrow
when trying trying to start without starter fluid it will try to start about every forth crank but never actually start
so im stumped
Any ideas???????????
OBD2A p75 ECU
so im stumped
Re: 97 civic will not start have checked pretty much everything in the book but this is my first OBD
i think your problem may be that you need an obd1 p75. trying to use an obd2 ecu with an obd1 engine will produce unhappy results. all electronics on the car need to be the same obd#. if you mismatch you'll run into problems
the senors from OBD1-2 produce the same signals just some of the clips have to be repinned is all.
not have the CPS or FIA(again i dont remeber the proper name for it) plugged in may cause an issue im thinking it might be fuel pressure at this point but not sure just looking for any other ideas at this point
We are also going to try chipping a obd1 ecu and try it with a jumper harness but this car in the end needs to stay OBD2 for emissions
Markb16a
13
11-08-2007 01:59 PM
