which wire harness do i use for my b16?
i have a 1993 honda del sol s(d15b7), with a jdm b16a swap, all odb1 parts on it...which harness do i use for it and where can i get one ? i want a clean one to not some ductaped pile of **** ,, thanks guys
Re: which wire harness do i use for my b16?
You can probably use your Del Sol's harness and add the needed terminals. Or wasn't there a 1994-1995 Del Sol that had the B16A? That would be a clean install. Or the harness out of a 1995 Civic EG6/EG9 with VTEC
I know with OBD2 I was able to use my SOHC VTEC harness to power a DOHC Motor with very little modification.
A few sensors had to be lengthened, and I had to re-wire the distributor. It will help if you can get the mating plugs from a junk yard or off the net
I have a MINT obd1 harness thats off a del sol that had a b16a. text me for pics and info if your interested 325-669-7434 names matt
rule of thumb when doing engine swaps is that u use and extend wires from the original harness to fit the motor ur swapping. the harness u have you may have to wire in vtec and pressure switch which isnt hard to do. a z6 harness would be the same exact thing as the b16 harness.
vonpatrick
19
07-08-2009 09:51 AM
nomotorsol
06-18-2004 11:42 AM
