97 acura el rear running lights
Old 06-15-2014, 11:56 AM
staz0loaf's Avatar
Default 97 acura el rear running lights
All my lights work except for my rear running lights. Changed my bulbs. (correct double bulbs for tails) checked all the fusses under dash. Is there a relay or w.e that controls the rear running lights? Cuz they work once I apply the breaks..
Old 06-15-2014, 01:23 PM
yippee-ki-yay
eHMxhACk's Avatar
Default Re: 97 acura el rear running lights
Have you checked your spelling or the forum you posted in.
eH.
Old 06-15-2014, 01:44 PM
I never narc'd on nobody!
NotARaCist's Avatar
eH.
Have you checked your grammar and punctuation, or your knowledge? If you're going to be a hypocrite, don't respond to people. If you don't know what you're talking about, don't respond to people.
OP, were the lights working prior to your replacing the bulbs (before they blew out)? do you have a voltmeter?
Old 06-15-2014, 02:16 PM
The Grumpiest
grumblemarc's Avatar
Have you checked ... the forum you posted in.
He's in the right place.
Old 06-15-2014, 07:36 PM
staz0loaf's Avatar
97 el is same as a civic 4dr so im in the right place.. sure my grammar is not great.
The light bulbs werent the issue since they looked fine when i changed them. i do have a voltmeter. seems like a common problem thats why im asking on a website not going to a mechanic to get it fixed. i read many threads with this common issue but people clunk up the thread and it never gets answered. anyone who had this issue before and fixed it please let me know
Old 06-15-2014, 07:37 PM
staz0loaf's Avatar
All the lights work as they should exept for my rear running lights when i turn my side markers or headlights on. when i break they come on and the bulbs are not the problem what should i be looking for?
Old 06-15-2014, 07:39 PM
NotARaCist's Avatar
Take your voltmeter and test two things. First off, with the lights on, probe the power wire in the light plug and see what voltage you get. Second off, test for continuity from the ground wire to the chassis. Post those numbers.
Old 06-16-2014, 04:16 AM
yippee-ki-yay
eHMxhACk's Avatar
I learn something new everyday. Punctuation was intentional. Spelling check still stands.
eH.
Old 06-16-2014, 04:25 AM
Former User's Avatar
Sounds like there's a broken wire in the trunk.
Old 06-17-2014, 08:52 AM
staz0loaf's Avatar
Im going check the voltage im getting at the plug. And I hope its not a broken wire in the trunk because everything is still original wiring wraped in the black plastic tube thingy, except for the speakers. Does the wires from the trunk run along the bottom driver's side doors?
Tyson Fabrick
11-11-2016 06:49 AM
William Reklaw
11-06-2016 04:41 PM
iwhichisme
06-06-2003 07:43 PM
Quick Reply: 97 acura el rear running lights
