96 civic lx won't start after it rains
Old 02-22-2014, 07:47 AM
DelSol-B18's Avatar
Default 96 civic lx won't start after it rains
My 96 civic lx will not start after it rains or after I go through a car wash. When I go to restart it everything is reset and the ecu is clicking. Also when it does start it will develop a low idle about 500 Rpms Is this moisture in the ecu? And it is a good idea to replace it? Thanks
Old 02-22-2014, 07:50 AM
Former User's Avatar
Default Re: 96 civic lx won't start after it rains
After a car wash, have you checked for moisture in the engine bay or around the ECU?
What's clicking is the main relay to the right of the glove box. When this happens, does the fuel pump fail to prime?
Originally Posted by DelSol-B18
everything is reset
What does this mean?
Old 02-22-2014, 08:06 AM
DelSol-B18's Avatar
Have not checked for moisture. The radio resets. And the clicking is coming right around the ecu/glovebox area. The fuel pump primes but all the power is very faint meaning low. Lights are dim blower motor barely works ect...
Old 02-22-2014, 08:08 AM
DelSol-B18's Avatar
Just checked. No moisture around the ecu
Old 02-22-2014, 08:11 AM
Does the starter crank the engine fine when the problem occurs?
Have you cleaned and tightened the G1 battery ground connection to the chassis, the G3 transmission ground at the chassis and transmission, and the G101 ground on the thermostat housing?
Have you checked whether the 7.5A hood Back Up fuse is blown?
Old 02-22-2014, 08:14 AM
DelSol-B18's Avatar
When the problem occurs it does not crank over. I will check all grounds and fuse
Old 02-22-2014, 08:16 AM
^key information missing in first post - definitely check all three grounds, especially G1 and G3.
Old 02-22-2014, 08:48 AM
DelSol-B18's Avatar
Ok grounds all sanded and cleaned. And 7.5 hood back up fuse not blown. So you don't think the ecu is going bad?
Old 02-22-2014, 08:51 AM
mike_1212's Avatar
ronJ on it as usual!! lol The world needs more like you man! keep up the good work.
Old 02-22-2014, 08:57 AM
Problem persists?
Not at this point.
Old 02-22-2014, 09:19 AM
DelSol-B18's Avatar
Seems to be ok right now! Going through a car wash soon lol
Old 04-07-2014, 02:58 AM
DelSol-B18's Avatar
Problem persists?
Not at this point.
Ok tried going to work this morning and the problem stil persists. Need your help ron. I sanded all grounds down and reattached. Please help me
Old 04-07-2014, 06:08 AM
DelSol-B18's Avatar
Is the main relay bad possibly?
Old 04-07-2014, 06:16 AM
Hatster89's Avatar
Does the problem only happen after getting wet? Is it fine during dry circumstances or does the low idle occur all the time?
Old 04-07-2014, 06:36 AM
DelSol-B18's Avatar
It is only when it gets wet. I got a car wash Saturday it was fine all day and Sunday. But this morning it occurs. Main relays keeps clicking continuously with key in on position. Also it's all I have a dead battery dash lights are dim. Headlights don't work. It's really weird
Justin Atkinson
03-16-2017 01:25 AM
Mike Arellano
12-29-2015 05:07 PM
Nick7
05-14-2011 08:57 AM
zx92027xz
08-31-2010 03:46 PM
Dateggy21
Acura TL, RL & ZDX
12-16-2009 07:52 AM
Quick Reply: 96 civic lx won't start after it rains
