CLUTCH ISSUES PLEASE HELP... SEARCHED
Old 01-09-2011, 01:28 PM
luvmihatch's Avatar
Default CLUTCH ISSUES PLEASE HELP... SEARCHED
Ok so i have a 95 ex coupe with a jdm d15b and a s20 ex si tranny.
when i start the car up u can hear a chatter when u push the clutch in it goes away. then when u drive between 2k and 4k rpm u can hear it the vibration again..
so im thinking clutch spring broken. throw out bearing maybe... what u guys think.. thanks in advanced.
Old 01-09-2011, 01:54 PM
MonkeyMagic's Avatar
Default Re: CLUTCH ISSUES PLEASE HELP... SEARCHED
you'd be correct. throw out bearing isn't any good.
now is a good time for a new clutch!
Old 01-09-2011, 02:03 PM
Former User's Avatar
This^ sounds like a bad main bearing (e.g., input shaft bearing) inside the transmission.
Old 01-09-2011, 02:09 PM
jaredperry's Avatar
Ok so the throwout bearing has been determined as being bad. Are there any updates to this?
Old 01-09-2011, 02:16 PM
What did you read here that led you to this conclusion?
Old 01-09-2011, 02:19 PM
luvmihatch's Avatar
yeah im hoping its not the input shaft bearing bc i really dont want to buy a new tranny.
im most probly going to drop the tranny and see what i can figure out... im hping i can just install a new clutch kit, bc it has a ebay xtd clutch kit on it now. and new bearing and hope for the best.
any one heard of this issue with the ebay clutch kits.. i didnt install it.. came on car just clarifying that lol.
Old 01-09-2011, 02:23 PM
Here's what you need to understand. In general, the throw out bearing is the problem if the noise happens with the clutch pedal pushed down whereas a transmission main bearing is the problem if the noise happens with the clutch pedal up.
Old 01-09-2011, 02:26 PM
hang on hang on.
i missed the part about 'goes away' when you push in the clutch.
i'd have to agree with ronj and say that your input shaft bearing has excessive play.. causing a bunch of ruckus when the transmission is spinning.
Old 01-09-2011, 02:33 PM
luvmihatch's Avatar
yeah its when the clutch is engaged is when the noise goes away. so i think that pretty much answers my question lol. when i start the car and have it in nutural with the clutch up is when u can hear it.
Old 01-09-2011, 02:36 PM
Drop and crack the tranny to check all of the main bearings, though the input shaft is the most common one to go. See the FAQs sticky.
Old 01-09-2011, 02:43 PM
luvmihatch's Avatar
yeah thats what ima probly have to end up doing.. pain in the *** but gotta do it right lol.
thanks guys ill keep u posted.
hcs1jimmy
04-19-2011 04:12 PM
Egreyes
04-15-2009 05:05 AM
maxogsr
06-22-2005 06:46 PM
mr_mbuna
12-04-2002 04:04 AM
Thirty-Nine
08-16-2002 04:20 PM
Quick Reply: CLUTCH ISSUES PLEASE HELP... SEARCHED
