'95 EG Cluster + Cruiser Control LED HELP
Old 06-02-2011, 09:34 PM
jdm_ek_noob's Avatar
Default '95 EG Cluster + Cruiser Control LED HELP
Before making this thread, i did some research and found this:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-eg-cluster-dash-lighting-modifications-2401422/
I'm still confused a bit about this and i didn't want to bring the thread back up so, are the cluster and cruise control led bulb's the same?(I'm only doing the cluster and cruise control bulbs) according to this i need 6 T1.5 bulbs (bottom of the page: http://www.superbrightleds.com/cgi-b...nstrument.html) for the cluster. Then it says: "All the switches use 3mm Neo-Wedges. There are 6 total. The Climate control uses #74 LEDs." The #74 would mean the T1.5 bulbs right? Before buying i just wanted to make sure, thanks for the answers.
Old 06-03-2011, 09:30 AM
danomatic93's Avatar
Default Re: '95 EG Cluster + Cruiser Control LED HELP
Originally Posted by jdm_ek_noob
...are the cluster and cruise control led bulb's the same?
No, the bulbs in the cluster differ from those in the switches. Don't confuse the cruise control switch with the cruise control bulb in the cluster itself.
You have a 96-00 Civic, right? This write-up is specific to the 92-95 Civic so you can only use this as a guide.
Old 06-04-2011, 04:44 PM
This isnt for my '99 civic, it was for my uncles '95 civic, he's the one who wants to customize his cluster/cruise control switch. So the cluster bulbs aren't the same as the one in the cruise control switch, correct?
ek9=]
01-21-2009 11:02 PM
vegaspartyy
03-15-2008 11:32 AM
9krpm
08-17-2004 07:02 AM
jlamaster
07-28-2003 06:05 PM
HuskerHybrid
12-20-2002 12:59 AM
Quick Reply: '95 EG Cluster + Cruiser Control LED HELP
