95 Civic Radiator Fan not running
Old 03-25-2011, 07:19 AM
Vurt's Avatar
Default 95 Civic Radiator Fan not running
My 1995 Honda Civic LX seems to be overheating alot. I'll stop the car whenever the car gets hot, and my radiator will be bone dry, Apparently my radiator fan is not turning on. The water/antifreeze in the reserve will be boiling for awhile and the cap pops off, i've replaced it 3 times so far and now i taped the sucker down so it wont go anywhere. I recently replaced the timing belt, waterpump, thermostat, radiator, coolant reserve, sparkplugs. All my fuses under the dash are good, Im not sure about the relay however.
Vurt is offline
Old 03-25-2011, 07:39 AM
Former User's Avatar
Default Re: 95 Civic Radiator Fan not running
Have you already thoroughly and properly bled the cooling system?
This may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
Former User is offline
Old 03-25-2011, 08:08 AM
j.bro's Avatar
ECT sensor will not engage the fan unless its submerged in hot coolant. Top up and bleed that cooling system.
j.bro is offline
Old 11-14-2011, 01:30 PM
philldeez's Avatar
I need some advice i think my relay switch is going out the fan only cuts on when it wants it seems wonder if there is a short in the wires or if it is going bad. all fuses are good any ideas and help. will be greatly thankful
philldeez is offline
Old 11-14-2011, 01:51 PM
lunalink's Avatar
thermostat may be bad. even if its new. what about your radiator ? is it still in good shape?
lunalink is offline
Old 11-15-2011, 02:37 AM
philldeez's Avatar
yes the radiator looks fine new therm.. sometimes the fan doesnt even cut on then sometimes it cuts on late and runs hot...strange. change of subject what kind of ecu chips preform good in a vtec?not sure how the 95 got up there its a 97ex is there a bleeder valve on the top to get the air out?
Old 11-15-2011, 05:36 AM
Jdubbs6101's Avatar
You can test the wiring and all electrical components easily if you know where your fan switch is...hint it should be right after your thermostat it's the big one.....take the plug off and put a jumper/short out the two pins in the plug this should turn on your fan if it doesn't you have a wiring issue if it does you probably need to bleed your system.....although you should bleed it anyway
Jdubbs6101 is offline
Old 11-24-2011, 05:26 AM
philldeez's Avatar
it must have had few pockets of air in the system thanks for your help! change the subject on you anyone ever try the ecu gforce chips haven't seen many good reviews on them. any names of good ones out there?
Old 07-28-2012, 12:03 AM
sladeripfire77's Avatar
question from : Vurt
"My 1995 Honda Civic LX seems to be overheating alot. I'll stop the car whenever the car gets hot, and my radiator will be bone dry, Apparently my radiator fan is not turning on. The water/antifreeze in the reserve will be boiling for awhile and the cap pops off, i've replaced it 3 times so far and now i taped the sucker down so it wont go anywhere. I recently replaced the timing belt, waterpump, thermostat, radiator, coolant reserve, sparkplugs. All my fuses under the dash are good, Im not sure about the relay however. "
First of all why did you have to change all that **** this thing beat up or something? # two....dont tape anything in your engine down with tape, if it blew the cap off that means there is pressure...your driving around with coolant fluid bout to explode in there,, FIX YOUR FAN.. You could be one commute away from a couple thousand dollars worth of engine damage making your daily driver a failing driver!!
sladeripfire77 is offline
fuglybutruns
07-28-2015 07:50 PM
NickyB92HCivic
10-17-2010 10:49 AM
delsolnewkid
14
02-06-2009 11:36 AM
spock_rocker
06-06-2005 03:32 PM
dockersguy
07-23-2004 09:01 AM
Quick Reply: 95 Civic Radiator Fan not running
