94 Dome light issues (need help)
I bought a 94 Honda civic and my dome light isnt working nor does it beep when the door is open and key is in the ignition. Its a DX model so its all manual no aftermarket keyless entry or anything like that. I pulled the switch off at the roof and everything looks to be par. I cant find out what the problem is. From what I have researched there isnt a dome fuse and have checked all of the fuses in the panel and everything is fine. The only thing I know put on the far that is not factory is HID headlights that the previous owner has installed. I have bought new bulbs, replaced fuses, done all that I know to do and still no luck. Does anyone else know anything else I can try on this car.
Things I have seen in other posts about this subject is:
will switch work if you switch to on?
No..
Does trunk dome work?
Used to when I fist bought the car now it doesnt.
Keyless entry wired wrong?
No keyless..
Maybe some of that will help idk..
No..
No keyless..
--ej1-Marie
14
08-23-2011 03:02 PM
lpdrumer
02-20-2011 04:25 PM
