94 Civic DX Crank, No Start
Hey guys, I've got a 94 Civic that won't start. It died on me one day, so I had to tow it home. Got it working temporarily by replacing the fuel pump, then it died again a few days later. I had it towed to an auto shop where they replaced the distributor. It worked fine for about a month after that, then it died again, and now it won't start. So far, the distributor, plugs, plug wires, TPS, fuel pump, and O2 sensor have been replaced recently. I've got spark and gas going to the engine, but it still just cranks. Before it died, it was running really rich and throwing CEL codes 43 and 15. Anyone have any ideas on what the problem might be?
Re: 94 Civic DX Crank, No Start
Ron: I've got strong spark on all four plugs, the injectors are indeed spraying fuel, and three of the four cylinders are within the correct range for the compression test
Larios: Apparently I forgot to say that the main relay has been replaced, sorry. As for the ECU, is there a way to test that if I don't have a similar one I can borrow from another car?
Thanks for the responses. Sorry I didn't respond sooner, the holidays have been a bit hectic.
Cylinders 1, 3, and 4 were all at 140-160ish psi, with number 2 not getting higher than 50.
The timing is good, the marks line up perfectly
94_civic_dx
11-05-2013 05:05 AM
slipyoke
11
04-22-2011 03:08 PM
ORguy
10
03-22-2011 05:25 PM
Herbie
04-21-2010 09:57 AM
