93 eg has brake shimmy
Old 11-10-2010, 07:35 PM
mattbatson's Avatar
Default 93 eg has brake shimmy
Damn this is pissing me off.
93 eg with 200K miles on it. I have replaced everything in the suspension, from koni's/GC coilovers, to new steering rack, tie rods (inner and outer), wheel bearings, and all the bushings are new poly.
Also brand new rotors.
Still have a shimmy, mainly under harder braking.
Tried rotating the wheels, but no difference.
I even took the brand new rotors in and had them checked at NAPA for runout.
What in the hell can be causing this shimmy? It feels like the tires are wobbling left to right at high frequency under braking (just to be clear what I mean by shimmy). It isnt a bounce, but a side to side shimmy.
thx
Old 11-10-2010, 07:50 PM
jdmh22eg2's Avatar
Default Re: 93 eg has brake shimmy
try to take off the wheels ALL OF THEM
retorque and torque in proper sequence-- improper sequence/ torque specs can give u brake pulse seen MANY MANY TIMES from sloppy/shitty tech
star pattern and 80 ft lbs IIRC on trq specs
Old 11-10-2010, 09:43 PM
norcarsol's Avatar
over tightened lugnuts with an impact???
can cause rotor to warp
if it's a shimmy due to other stuff it won't be just during braking.
Old 11-10-2010, 10:09 PM
hOnda_hiEn's Avatar
try bleeding your brakes.
Old 11-11-2010, 03:45 PM
mattbatson's Avatar
I'll try that. I even have another set of wheels that I'll try on there and see what happens.
thx
Old 11-11-2010, 03:48 PM
mattbatson's Avatar
hey, they are bled. I have a motive self bleeder and even have a new master cylinder on there
Old 11-11-2010, 03:49 PM
mattbatson's Avatar
hey, no I torque wrench everything
Old 11-22-2010, 06:36 PM
mattbatson's Avatar
alright, so I put on my new konig 15x7's with new tires and the brake shimmy is still there.
everything on the front end is new.
any ideas?
Old 11-22-2010, 08:10 PM
spun95's Avatar
have you replaced your lower ball joints?
Old 11-23-2010, 06:24 AM
KevinBrown's Avatar
You didn't say in the original post, but did you replace your brake pads?
Old 11-27-2010, 05:56 PM
mattbatson's Avatar
hey guys, yes everything has been replaced on the front end.
all ball joints, all bushings, all tie rod ends, brand new brake pads, brand new rotors, wheel bearings, steering rack, etc.
I cant believe I'm having this problem as my crx doesnt do this and I have yet to touch it's 200K mile front end.
Old 11-27-2010, 08:18 PM
spun95's Avatar
idk bro i would double check everything and make sure all your ***** tight.
juniorpopper
06-07-2013 08:40 PM
EFing8
18
07-29-2009 02:13 PM
Takeoff
12-15-2002 05:39 PM
AMG
10
11-19-2002 05:11 PM
Quick Reply: 93 eg has brake shimmy
