93 Del Sol Turn signals and hazards stopped working
Old 01-24-2013, 02:37 PM
m.glisson003's Avatar
Default 93 Del Sol Turn signals and hazards stopped working
Okay so a couple days ago I started driving my car and all of a sudden the turn signals and the hazards aren't working anymore. They don't work outside and they don't work in the cluster either. When I engage them I dont even hear the clicking noise like you would normally hear. I checked all of the fuses underneath the dash and in the engine bay and all of them are good. I double checked to make sure fuse #15 is good. I also replaced the flasher relay that I circled in red on the diagram. I'm not sure where to go from here. Anyone have an idea as to what the issue could be?
Old 01-24-2013, 05:53 PM
belairbrian's Avatar
Default Re: 93 Del Sol Turn signals and hazards stopped working
Did you check fuse 43 in the under hood fuse box?
Old 01-24-2013, 06:19 PM
Yes I did check that fuse and that one was good too.
Old 01-24-2013, 06:37 PM
Ok. Not sure what that part in the fuse box really is. It's labeled TO turn signal hazard relay. My Shop manual shows the actual turn signal/hazard relay being mounted on a bracket in the drivers foot well. Same bracket as the aux light relay. It should have 6 wires going to it.
Old 01-24-2013, 08:38 PM
Alright so here is the scoop. After I read your reply above I went back and found the actual relay. Its behind the fuse panel to the left of the clutch. It actually had 9 wires going into it but it does have 6 connectors on it. I took it to the auto parts store to get a replacement and found out it is $125. Don't even want to imagine what it cost at the dealer. So tomorrow I will be going around to junkyards to find a replacement. I hope it works! Thanks for your help!
Old 01-25-2013, 08:22 AM
I think I'd learn hand signals
But for sure I'll be scrounging a couple at the next pull a part trip
Chris09
06-09-2022 08:05 PM
tallguy21
05-17-2012 04:13 PM
Masho
Honda Civic (2001 - 2005)
07-17-2010 02:24 PM
5thGenFanatic
11-06-2006 10:32 AM
RiCeRTeG
03-16-2005 04:19 PM
Quick Reply: 93 Del Sol Turn signals and hazards stopped working
