92 Civic - power locks problem - only driver side door unlocks with the key
Old 10-02-2010, 06:49 AM
mr_munro's Avatar
Default 92 Civic - power locks problem - only driver side door unlocks with the key
hey in my 92 eg, both doors lock when i turn it with the key from the drivers door but when it comes to unlocking, its only the driver side that unlocks ...both doors use to unlock but not anymore...anyone had this problem and know how to fix?
thanks
Old 10-02-2010, 07:07 AM
Former User's Avatar
Default Re: central unlocking stopped working!
Does the inside driver's door switch unlock both doors?
Old 10-02-2010, 08:29 AM
mr_munro's Avatar
nope...the latch can lock both doors but not unlock.
Old 10-02-2010, 09:02 AM
Default Re: 92 Civic - power locks problem - only driver side door unlocks with the key
Old 10-02-2010, 09:11 AM
mr_munro's Avatar
no idea i take it then? lol, its got me stumped aswell...
Old 10-02-2010, 09:13 AM
The idea is implied by the posted diagram -- test the passenger side actuator.
Old 10-02-2010, 09:55 AM
mr_munro's Avatar
ah sorry, no diagram comes up on my work PC...do u have a direct link?
thanks
Old 10-02-2010, 08:10 PM
mr_munro's Avatar
now that i see the pic (im noob to these trouble shooting ideas) when it says battery source connected to the no.2 terminal, what battery source do you suggest? as in what kind of battery will supply enough voltage?
thanks
Old 10-02-2010, 08:14 PM
thanks
You can run a wire directly from the car battery.
Old 10-02-2010, 08:19 PM
mr_munro's Avatar
and then just ground it somewhere on the door chassis?
Old 10-02-2010, 08:28 PM
Oh look, I can change this
deschlong's Avatar
^ Yes, or ground it back to the neg of the battery. Actually, you can use any 9-14V DC source ... I find a power drill battery works well and is more convenient than the car battery. However, I am suspicious of the description you gave - it sounds to me like you might have a European/Oz/etc. car? North American vehicles have a switch to unlock the passenger doors - they do not all unlock with the key (lock yes, unlock no).
You can use the frame under the dash or the battery ground terminal.
Old 10-02-2010, 08:36 PM
mr_munro's Avatar
Im from australia, so yea aussie model. the only 'switch' i am aware of, is the latch inside the drivers door and the passenger door, but only the drivers door latch and key from the outside locks and use to unlock both doors.
Old 10-02-2010, 08:54 PM
deschlong's Avatar
That's what I thought. Well, Ron is on the right track with you, but I will post some troubleshooting diagrams specific to a "switchless" power lock system (ie., just the key and the latch you mentioned.)
Old 10-02-2010, 09:01 PM
mr_munro's Avatar
thanks it will b so helpful!!
Old 10-02-2010, 09:06 PM
deschlong's Avatar
Here you are. If the actuator is bad, then it's possible you can fix it instead of replacing. Have a look anyway, at least.
Old 10-02-2010, 09:14 PM
mr_munro's Avatar
wow where do i start lol
Old 10-02-2010, 09:24 PM
deschlong's Avatar
Start at the Troubleshooting diagram, mate.
Old 10-02-2010, 09:29 PM
Test the passenger lock actuator, as discussed earlier and as shown in the diagram in post #4.
Old 10-02-2010, 09:43 PM
mr_munro's Avatar
will post up tomorrow how i go, thanks again
lrhtech
07-13-2015 05:30 PM
Mik3
02-08-2006 10:08 PM
blu92
01-11-2006 11:26 AM
MADEINIRAQ
08-25-2004 07:59 PM
Heat
08-05-2003 02:36 PM
Quick Reply: 92 Civic - power locks problem - only driver side door unlocks with the key
