92 Civic With B16A Not Warming Up! Help
have a 92 civic with a b16a in it with a p30 ecu. Car is currently not warming up past the 1st line when driving. If i let it idle in my driveway, which is on a slight slope for a few minutes the coolant temp gauge will move to about 1/3rd of the way warm. But when i go take it around the block it drops again to almost zero. Do you think i have a stuck open thermostat or any suggestions? thanks
Re: 92 Civic With B16A Not Warming Up! Help
Well i just changed the thermostat, and that didn't solve the problem. In fact now the water temp gauge doesn't move AT ALL. And the lower radiator hose is not pressurized and cold, while the top is pressurized and warm. So my only guess now is that the lower radiator outlet is clogged. ANY Suggestions? imma take radiator off tomorrow.
If the fluid's not circulating, the temp sensor may not be getting the warmed up fluid run across it. I'm not sure where the temp sensor is located in the path of fluid, but if the fluid around it isn't getting warm, it'll always read cold.
1- be sure you installed the thermostat properly, with the pin hole at the top. (I put one in upside down once and it didn't warm up properly)
2- while the engine is cold and hasn't been run, start the car and then take off the radiator cap to be sure the coolant is circulating and there are no air bubbles in the line.
3- if none of that works out, take the radiator out and try running the hose through it to make sure it's not plugged. Note: flush the radiator well while you have it empty
yeah maybe bleed the system or check ur cooling fan coolant temperature sensor,coolant temperature sensor and your temperature gauge sending unit sensor all on the side of the head under the dizzy take them off clean them off or replace them hope this helps
PolePosition08
12-01-2010 07:33 PM
billythepunk21587
03-02-2008 01:15 PM
JDM_CRX_PLEASE
02-01-2008 03:30 PM
project civic
03-16-2006 09:46 AM
