2000 DX distributor question (solved)
Old 01-11-2015, 08:19 AM
Tampa Dave's Avatar
Default 2000 DX distributor question (solved)
Hi all.
Newbie poster, pre-apologize for any forum gaffes.
This is cross-posted to civicforums, so if cross-posts are a no-no, let me know and I will remove it.
Elderly friends car, left sitting for 2 weeks and now a no start.
Have some automotive knowledge and tools.
Symptom: No start
Facts so far:
No CEL/codes.
Cranks.
No spark on any plug wire
Replaced coil. No help.
Have LED tester and have been probing 8 wire distributor harness in attempt to isolate starting point of issue.
According to diagnostic I found on internet, when engine cranked I should get an off/on pulse on 1 of the 2 harness wires nearest the firewall.
I'm getting power on LED when ignition in position II but no LED at all when engine being cranked.
My electrical system experience is a bit limited.
Can I get a confirmation that this behavior is:
1. wrong
2. indicative of PCM/ECM failure
or
3. possibly an ignition key/cylinder short.
TIA.
Dave
Tampa Dave is offline
Old 01-11-2015, 09:20 AM
Technical Hero
HondaPartsHero's Avatar
Default re: 2000 DX distributor question (solved)
When you turn the ignition does the check engine light come on for 2 seconds then turn off (not fully cranked)
HondaPartsHero is offline
Old 01-11-2015, 10:28 AM
Tampa Dave's Avatar
I will have to double check, but I don't think it is coming on.
Not near car right now.
I was going to pull the MAF connector to see if I could force a code and then assume it was a burned bulb.
What's the "no CEL at POST" indicative of?
Thnx!
Dave
Old 01-11-2015, 12:02 PM
Technical Hero
This is the main relay not working. It's a VERY common issue on Hondas. Check the FAQ above for troubleshooting.
Old 01-11-2015, 12:42 PM
Tampa Dave's Avatar
Thanks for that.
Sorry, new to forum.
If I go FAQ > Search FAQ and put in "main relay" (with quotes) I get no hits.
Probably just the location of that specific relay would be enough to get me started.
Old 01-11-2015, 02:07 PM
spAdam's Avatar
Right of the glovebox, kind of inside the dash. Drop the glovebox and give it a few taps with the handle of a screwdriver or butt of a small hammer, sometimes brings it back to life temporarily. You hear it click, the MIL will come on for 5s, and the fuel pump will prime if you were successful. Replace it anyway. The mounting bolt is accessible by pulling the trim panel on the end of the dash, facing the door panel.
spAdam is offline
Old 01-11-2015, 07:03 PM
Former User's Avatar
Does the fuel pump prime?
Does the CEL work, a asked by HondaPartsHero?
Former User is offline
Old 01-12-2015, 07:56 AM
Tampa Dave's Avatar
Nice shooting guys.
Main relay it was.
I now have a running vehicle.
Next.
Not sure if this was happening prior to relay failure, but car surges at idle.
In D with foot off pedal it will do 25 mph.
Battery has been drained/disconnected a few times.
Something the ECM/PCM needs to relearn?
IAC/IAT issue?
Thanks again.
Dave
Old 01-12-2015, 12:09 PM
Tampa Dave's Avatar
Close this thread.
Replaced IAC and back to normal.
Thanks for the help.
Great forum.
Dave
Old 01-12-2015, 12:56 PM
Hysterically Calm
TomCat39's Avatar
Default Re: 2000 DX distributor question
Originally Posted by Tampa Dave
Thanks for that.
Just for your info, hoping you see this.
The H-T search engine doesn't work well, using google is much more effective. For this search I would probably do "site:honda-tech.com Main Relay FAQ HondaCivc/Del Sol 1992-2000"
I believe that will provide a much better result mainly in this forum and quite likely from the FAQ.
TomCat39 is offline
Jaynik
46
12-04-2013 05:29 PM
clean95hatch
12-13-2012 09:13 AM
89hondacivicdx
13
09-17-2011 05:43 PM
95turbotypeR
12-15-2010 05:58 PM
Dokta
01-24-2008 10:00 AM
Quick Reply: 2000 DX distributor question (solved)
