2000 Civic Low Idle, Stalling
Old 10-25-2010, 12:51 PM
Joshbarry's Avatar
Default 2000 Civic Low Idle, Stalling
Hey everyone,
I am new to this forum and joined because I need some help. A few months ago I purchased a 2000 Honda Civic EX 4Spd Automatic off of craigslist and it has not stopped giving me problems. Currently I have two trouble codes: P0113 IAT sensor circuit high voltage, and P0172 Fuel system too rich bank 1. Also, the car idles very rough and very low and will stall out at unless I put it in neutral and rev the engine coming up to a stop.
So far I have replaced the following parts:
Primary O2 Sensor
IAT Sensor
Water pump
Spark plugs/wires
Distributor cap/rotor button
I have also recently cleaned out the throttlebody and ran a bottle of fuel injector cleaner through the engine.
Im stumped. Thanks in advance for any help.
Josh
Old 10-25-2010, 01:12 PM
Former User's Avatar
Default Re: 2000 Civic Low Idle, Stalling
Does the 2P connector plugged into the IAT sensor have a Red/Yel wire and Grn/Blk wire? If so, check both wires, which run from the IAT connector to ECU C18 and C25) for a short or open.
P0172 - check whether the FPR is stuck closed or a fuel injector is stuck open.
Old 10-28-2010, 06:16 AM
Joshbarry's Avatar
Sorry to take so long to reply.
I checked the wires with an Ohm Meter yesterday and they had very little resistance. Is this a good sign? Is there a better way to check for shorts?
I checked the fuel injectors, and they all were fine. Haynes doesn't say how to check the FPR. Any suggestions?
Also, as far as the idle/stalling goes, could I possibly need a new PCV Valve? Would that cause these symptoms? Also, the IACV is not in the place it should be. I think instead it is mounted on the bottom of the throttle body but I have read that that is a FIT not and IAC. Is it possible I dont have an IACV and that is what is causing the problem?
Josh
EricEJ8
04-01-2019 08:22 PM
curt9021
17
10-28-2014 07:45 AM
Karben
27
06-24-2014 05:59 PM
soxfan7290
11-10-2009 09:10 PM
Quick Reply: 2000 Civic Low Idle, Stalling
