2000 Civic Ex low idle and stalling
Old 01-18-2013, 02:01 PM
elnoyl's Avatar
Default 2000 Civic Ex low idle and stalling
There is no cel on. When the car is warmed up it idles so low the tach barely has a reading and completely dies and has to be restarted. Accelerating and driving seem to be normal. I just have to keep pushing down the gas to keep the car from stalling out. It's a d16y8 with a manual transmission.
Old 01-18-2013, 02:37 PM
KevinVX's Avatar
Default Re: 2000 Civic Ex low idle and stalling
Have you checked your IAC valve yet? It might possibly be dirty enough to cause idling issues which is fairly common. I have a similar issue on my 1995 VX. My car idles at about 500 rpm and the idle will sometimes fluctuate as well but, my car never actually stalls.
Old 01-18-2013, 03:11 PM
Former User's Avatar
I agree^.
Start by cleaning the IACV. Click the link in my signature.
Does the CEL work?
Old 01-18-2013, 03:14 PM
hytech_shed's Avatar
Remove your throttle body and clean it real well with TB or carb cleaner.( watch not to damage the gasket otherwise you'll need a new one )..Do the same with The IACV....also get some Injection cleaning additive and dump it in your gas tank...run it for a few miles...and see how it goes.... It should fix your issue....( considering there is no cel it should be a mechanical problem )....
Old 01-18-2013, 03:17 PM
Actually, an IACV mechanical problem will typically throw P0505 for an OBD2 Civic. That's why I was asking whether his CEL works.
Old 01-18-2013, 03:24 PM
elnoyl's Avatar
I cleaned the IACV and its still doing it. The cel does work but is not on. I have noticed that it only goes really low or dies when it's fully warmed up. If I rev the engine, the idle will go really low or die.
Old 01-18-2013, 03:26 PM
There's a diagram in the FAQs sticky that describes how to adjust the idle speed of your D16Y8 engine/transmission. Try that and then go from there.
Old 01-18-2013, 04:02 PM
elnoyl's Avatar
I have had this car for almost 4 and a half years. It has been fine with the idle up until now. That makes me think something is dirty, broken etc and adjusting the idle is more of a bandaid and not a repair.
Old 01-18-2013, 04:15 PM
Suit yourself. Adjusting the idle speed is basic maintenance, not a Band-Aide treatment. Just trying to point you toward potential fixes for your problem.
What have you recently done to the car? Have you reset the ECU? Any Maintenance?
Old 01-18-2013, 04:33 PM
KevinVX's Avatar
Believe it or not, I had an S13 that would turn off if I didn't hold my foot on the throttle. I took it to my mechanic to see what he thought of it and he adjusted the idle speed. Afterwards, the car stayed on by itself and idled at the proper level as well. I didn't think that would be the cause of my issue either but, it's worth taking a look at. If I were you, I would actually be relieved to know that the solution to my problem was as simple as adjusting the idle speed.
Old 01-18-2013, 05:01 PM
elnoyl's Avatar
I wasn't trying to come off rude. I just figured it was about adjusting the screw and not the entire procedure that is outlined in the helms. Nothing really just an oil change. I will give it a try and report back.
Old 03-19-2017, 11:53 AM
Joshua Coop's Avatar
Having the same problem, Maybe my computer? Ive got a phearable ecu
HondaCivicSE
05-30-2014 01:53 PM
99GreenEX
11-29-2007 07:52 PM
Layziebtnh055
09-01-2004 02:38 AM
Layziebtnh055
08-31-2004 03:07 PM
Quick Reply: 2000 Civic Ex low idle and stalling
