TPS sensor questions
Old 01-11-2012, 08:49 AM
what gsr's Avatar
Default TPS sensor questions
Ok ive searched (i promise) and i haven't found anything to answer my questions.
I bought a brand new Omni 68mm Tb and an omni TPS. I cant get the tps to calibrate right.. with the multimeter set on 20k ohms the lowest i can get is .79 out of the omni tps and .59 out of the stock tps.. could there be something wrong with the throttlebody its self? the butterfly is completely closed and te idle screw all the way out..
any ideas? thanks!
Old 01-12-2012, 08:26 AM
what gsr's Avatar
Default Re: TPS sensor questions
Anyone?
Old 01-12-2012, 08:42 AM
The Grumpiest
grumblemarc's Avatar
Sounds like an Omni Power issue since they claim their sensor are the same as stock.
http://omnipowerusa.com/contact.asp
Old 01-12-2012, 11:28 AM
Technical Hero
HondaPartsHero's Avatar
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
Old 01-12-2012, 12:28 PM
Former User's Avatar
any ideas? thanks!
You are probably just setting your multimeter to the wrong Ohm scale (20K = too high). Set your multimeter to the Ohm scale closest to 1K Ohms.
408h22a1
02-27-2013 07:41 PM
Jakester9500
11-19-2008 07:10 AM
ITR.#1446
09-04-2005 12:17 AM
wu tang
07-01-2003 08:27 PM
boosted hybrid
04-01-2002 06:20 AM
Quick Reply: TPS sensor questions
