d16y7 head on d16z6 block
Old 02-16-2011, 01:31 AM
youryanyou's Avatar
Default d16y7 head on d16z6 block
ive read a lot about this but unsure what timing belt to use or headstuds im always reading 2 different stories.im planning to go boost i have all my parts and a z6 block sitting.i rather use that due to y7 oil pump.and im doing y7 head since i want to keep my port and regrind cam.i just need to know what studs timing belt pully all that good stuff.p.s this is going to be vitara block with y7 head.
thanks honda tech
Old 02-16-2011, 01:32 AM
youryanyou's Avatar
Default Re: d16y7 head on d16z6 block
also i will be buying arp headstuds but unsure which model to buy y7/8 or z6
Old 02-16-2011, 08:50 PM
youryanyou's Avatar
Old 02-17-2011, 05:19 AM
92lxsleeper's Avatar
you get the headstuds for whatever cylinder head you are working with. in your case a y7. but i must ask why are you using a y7 cylinder head over a y8?
Old 02-17-2011, 06:20 AM
apexi_rsx's Avatar
he said he has a ported y7 head and regrind cam thats why hes reusing the y7 head.
Old 02-17-2011, 06:50 AM
speedooo's Avatar
For the headstuds, use d16y7 pieces. The threads in the block are most likely identical, I know with a d16y8 and a d16z6 the bolt closest to the distributor is a different length but the threads in the block are the same, it's a difference in the head.
Honda Part Numbers:
D16y7 Timing Belt 14400-P2F-A01
D16z6 Timing Belt 14400-P28-004
D16y7 Head Gasket 12251-P2J-004
D16z6 Head Gasket 12251-P08-004
Advance Auto Pieces:
FelPro D16y7 Head Gasket 9915PT
FelPro D16z6 Head Gasket 9915PT
BeckArnley D16y7 Timing Belt 026-0307
BeckArnley D16z6 Timing Belt 026-0307
Old 02-20-2011, 10:46 PM
youryanyou's Avatar
thanks man u helped a lot! just finished my vitara block now needa order up some headstuds ana start breaking it innn.so z6 and y7 timing belts the same?
Old 02-20-2011, 10:50 PM
youryanyou's Avatar
nvm!just searched read that it has the same tooth count.
non vtec ftw
Old 08-24-2021, 02:42 PM
CHR1SC3ND0's Avatar
question, I got a 91 si with the z6 block and a y7 head i salvaged cause I snapped the cam in my a6 head, well the distributor for the y7 which I believe is obd1, won't secure except with one bolt, is your problem the same? If so how does it affect driveability?
I haven't timed it yet or even torqued it down because it's not TDC yet. Just wanna know if I can drive it with only one bolt in. And will it stay timed? Don't want the distributor blowing up or popping out
Syke909
06-19-2013 04:12 PM
Syke909
06-01-2013 11:20 PM
Jayboy
04-23-2005 03:43 PM
94maroonturbocp
04-27-2004 06:19 PM
JSPECHB
05-11-2003 07:29 PM
Quick Reply: d16y7 head on d16z6 block
