[FAQ] What parts are interchangeable for all 92-00 Civics?
Old 12-06-2004, 05:39 PM
  #51
cnyej1's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">As for front calipers:
Civic 92-00 EX and 99-00 Si (em1) share the same size caliper (including piston size), knuckle, and rotor.
Integras 94-01 share that same identical rotor size, and caliper bracket - which means Integra front calipers bolt directly onto the civic ex/si knuckle. The pistons are noticeably larger.
The Civic ABS setup is IDENTICAL to that of the Integra.
The rest of the 92-00 civics, and eg si hatches will need an ex, em1, or integra front knuckles to bolt the larger brakes on, as the brackets are smaller in size.
Im confused by this.... i thought that the Ex's with ABS were the same size. Not all Ex's came with ABS..... my 94 doesnt have it.... thus making it need the front knuckles right?
Old 12-12-2004, 09:35 PM
  #52
zer0.'s Avatar
Default Re: (cnyej1)
kind of simple..but if you put a 92-93 dash in a 94-95 civic....you MUST use the 94-95 glovebox,the 92-93 glovebox won't close (92-93's didn't have airbags so they are slightly different.) i learned this after i put a 92 dash in my 94 hatchback,no more blue interior.
Old 12-19-2004, 05:05 PM
  #53
95stangkillah's Avatar
Default Re: (zer0.)
92-95 coupe/sedan/hatch sideskirts are all different. , 92-00 civic struts and springs are interchangeable. U gotta u zip ties to secure the struts if u use 96-00 struts on 92-95. 94-01 Integra bolts up to 92-95 with no problem. 94-01 integra rear conrtol arms and rear sway bar, bolt up to 92-95 civic. 94-01 integra seats bolt up to 92-95. 96-00 axle back muffler bolts onto 92-95, 94-01 front brakes whole spindle, bolt up to 92-00 civic. 92-95 all gauge clusters are plug and play. 99-00 civic radio console wont fit in 96-98 civic. 99-00 dashboard will bolt up to 96-98 civic, 99-00 si rear control arms, and sway bar bolt up to 96-00 civics. 92+ civic and integra sunvisors are all interchangeable. 96-00 civic radios are not plug and play for 92-95, 88-95 radios are plug and play. 92-00 civic hatchback rear seats are all interchangeable. 96-00 wiper arms will work on 92-95, 96-00 civic sun visors fit on 92-95. 96-00 civic inside rearview mirror will work on 88-91 civic. 92-95 civic coupe and hatchback doors are interchangeable, 88-95 non vtec sparkplug wires are interchangeable. 92-00 civic radiators are interchangeable. 99-00 civic coupe taillights bolt up to 96-98, 88-00 civic shifters are interchangeable. 92-95 civic headlights are all interchangeable. 94-01 integra fuel pumps are interchangeable with 92-95 civic. 88-95 civic, accord, integra main relays are interchangeable. 94-95 integra injectors are interchangeable with 92-95 civic. 93-97 del sol seats will bolt onto 92-95 civic when swapping brackets, 94-00 integra front control arms and sway bar bolts up to 92-95 civic. there's still alot more I have experienced, I'll post more once I remember.
Old 12-19-2004, 06:28 PM
  #54
mattharper's Avatar
Default Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (kleanlscivic)
"arent all sideskirts interchangeable on 92-00 civics?"
no, to put 6th gen sideskirts on a 5th gen you gotta make new hole for the clips to snap into, and i donno about 96-00 onto 92-95...but who would so that anyways
Old 12-20-2004, 03:52 PM
  #55
SniperRCivic's Avatar
sorry i needed a second opinion i started a thread wanting to know if the intake mani off of a 88 ls d16a1 dohc integra will fit on a 98 dx d16y7 civic sohc
Old 12-20-2004, 03:56 PM
  #56
71.192.16.183
jlacoy82's Avatar
Lets get some info on interchangeable cranks and blocks!
Old 12-23-2004, 10:29 PM
  #57
Mike Jones
SlowPokeEg's Avatar
Default Re: (jlacoy82)
OK, we know EG doors arent ALL interchangable, but as far as the door HANDLES, what are we lookin at here? (i need a new one and wondered if sedans were compatable)
  #58
cnyej1's Avatar
Default Re: (SlowPokeEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowPokeEg &raquo;</TD></TR><TR><TD CLASS="quote">OK, we know EG doors arent ALL interchangable, but as far as the door HANDLES, what are we lookin at here? (i need a new one and wondered if sedans were compatable)</TD></TR></TABLE>
Same
Old 12-23-2004, 11:10 PM
  #59
Mike Jones
SlowPokeEg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cnyej1 &raquo;</TD></TR><TR><TD CLASS="quote">
Same </TD></TR></TABLE>
*Mr. Burns* "Excellent Smithers......."
Old 12-29-2004, 07:07 PM
  #60
mp5o's Avatar
Does anyone know if an IACV from a z6 will fit onto a y8? Thanks in advance....BUMP
Old 12-29-2004, 07:59 PM
  #61
FWejCOUPE's Avatar
Default Re: (mp5o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mp5o &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if an IACV from a z6 will fit onto a y8? Thanks in advance....BUMP</TD></TR></TABLE>
yes and it will also fit b16 and gsr im's.
Old 12-30-2004, 11:28 PM
  #62
Jj0o3eyY's Avatar
Default Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (SOHC4life 96)
saved.
Old 01-03-2005, 07:55 PM
  #63
pearl's Avatar
Default Re: (95stangkillah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95stangkillah &raquo;</TD></TR><TR><TD CLASS="quote">92-00 civic struts and springs are interchangeable.
U gotta u zip ties to secure the struts if u use 96-00 struts on 92-95. </TD></TR></TABLE>
zipties? care to explain? i plan on selling my springs/struts off my 96-00 to someone with a 92... curious to how hard is is to make the rears fit...
Old 01-03-2005, 08:18 PM
  #64
NitrousB.I.G.'s Avatar
Default Re: (japearl)
Do the 94 and up integra rear seats fit in a 92-95 civic? I think that I read something about this, they were talking about a gap at the bottom or something.
Old 01-03-2005, 08:42 PM
  #65
PABLOHONDA's Avatar
Default Re: (NitrousB.I.G.)
i have been wondering the same for awile now but in a coupes is it the same as the hatch and what carpets fit what.
92-95 coupes w/ gsr swaps you can use a 00 civic si dc or whatever header of chose it fit the cat.
Old 01-03-2005, 08:47 PM
  #66
Solo2EG's Avatar
I have the same question about rear seats too... will DC 'teg sedan rears fit in my EG Sedan? I'd love to pick some up to match my 'teg fronts.
Old 01-03-2005, 08:55 PM
  #67
civictildeath's Avatar
Default Re: (Solo2EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PABLOHONDA &raquo;</TD></TR><TR><TD CLASS="quote">what carpets fit what..</TD></TR></TABLE>
pretty sure all carpets are interchangeable at least within the same model years 96-00 2/4dr/hatch work together and 92-95 2/4dr/hatch work together but im not sure if 92-95 will work in 96-00 or vice versa
the seat issue has been settled before
Old 01-07-2005, 01:47 PM
  #68
xoutlawz00x's Avatar
Default Re: (civictildeath)
do 96-98 hacth doors fit 99-00 coupe doors!! vice versa
and what door fit what.. im talking about whole doors
Old 01-18-2005, 12:17 PM
  #69
timesnap's Avatar
Default Re: (xoutlawz00x)
B-series Exh. Manifolds (b16, b18, b20) bolt up to stock EG civic exhaust systems Dunno about the rest of the civic series.
Old 02-05-2005, 12:33 PM
  #70
sightless's Avatar
Default Re: (Redline96LX)
OMG STFU I JUST PUT 96-98 on my 99-00 MR.misinformation... ******* ***... thats why Atlanta "Hotlanta"has the highest rate of aids anywhere.
My cars a SEDAN BITCH...
Don't ******* MISINFORM.
Old 02-07-2005, 03:12 PM
  #71
Pearl Crx's Avatar
Default Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (civiccpedx)
You can bolt a y8 tranny up to a z6, but teh lines for the hydrolic clutch are in different places. So adjust accordingly.
Old 02-07-2005, 03:14 PM
  #72
Pearl Crx's Avatar
99 Ex sideskirts are 2 inchs two long to fit a 92-95 hatch.
Old 02-08-2005, 07:56 PM
  #73
POWERINTEGRA's Avatar
Default Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (Pearl Crx)
do any of the DA parts fit the 92-95 eg HB????
Old 02-09-2005, 01:34 PM
  #74
hypoxvi's Avatar
You can use the exhaust from an EG hatch or EX coupe (or any exhaust made therefore) on an EK. You have to switch to a header from a EX coupe, and use the cat for an EX coupe as well. Then you just have to lengthen the wires for the second O2 sensor, and route it down and put it in the bung after the cat.
Another option rather than replacing the whole exhaust, is to use a testpipe (or one of those "high-flow racing cats off eBay, it's just a hollow resonator) and place that in the gap where the cat would go.
The second option is generally less costly and easier to do, if you can manage not to snap the bolts on the down-pipe, but we all can't be that lucky.
Old 02-13-2005, 01:43 PM
  #75
3RdT's Avatar
Default Re: [FAQ] What parts are interchangeable for all 92-00 Civics? (hypoxvi)
-96-up coupes and hatchbacks share the same length in sideskirts(interchangeable).
-i believe all 92-up hatch axle back r the same.
-92-up axles r interchangable
-s2k steerinwheel would fit 96-up civics. (seen on a fellow ht member's car)
Quick Reply: [FAQ] What parts are interchangeable for all 92-00 Civics?
