**Rear Caliper piston seized. Need ASSISTANCE**
* B A N N E D *
My Passenger rear caliper piston is seized on my 00 Si rear brakes. I am by no means a mechanic.. but have always changed my brakes pads myself.... etc. I was wondering how hard it is to change out a caliper?
Any help is appreciated thanks
* B A N N E D *
Re: (civtic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civtic »</TD></TR><TR><TD CLASS="quote">you could probably free it, try greesing the guide pins, or even working the piston in and out (but make sure it doesn't pop out), worked for me!</TD></TR></TABLE>
The piston isn't moving at all, its been seized for a while by how the brake pads were worn. The outer pad was completly worn to nothing while the inner pad still had some life on it
oh well, as you said then easiest thing would be to just replace it. Very easy job as long as you've got someone to pump the pedal for when you bleed the system again.
1 Post
Re: **Rear Caliper piston seized. Need ASSISTANCE** (BB4lude)
You do know the pistons need to be "spun" in not just pushed in like the front right?
If they are really seized just get 2 remaned ones, they should be like $50
Re: **Rear Caliper piston seized. Need ASSISTANCE** (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">You do know the pistons need to be "spun" in not just pushed in like the front right?
If they are really seized just get 2 remaned ones, they should be like $50</TD></TR></TABLE>
x2, the rears screw in also make sure to grease the guide pins
gl
gl
jadmEM1
06-07-2007 06:05 PM
crxcess
10-09-2002 10:50 AM
wickedxbo1
12-30-2001 07:51 PM
