Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Window not rolling up for some reason.
Old 01-07-2010, 11:54 PM
425_Booster's Avatar
Icon2 Window not rolling up for some reason.
I took my door apart today to replace my side mirror due to a guy very nearly going head on with me, but swiping my mirror. Anyways. Before I put my door skin back on I made sure the window wasn't catching any of the wires. I was rolling up my window in the non-auto (holding the switch up) setting and it would go up and hold. When I rolled it up in the auto setting it goes up then immediately comes back down 3''-4''. Im not sure what the problem is because I didn't touch any of the cables, and it stays up when you don't ''auto roll'' it up.
Could it have possibly changed some setting that I need to reset because I had to disconnect the window wiring? Do I need to turn my key or press my window buttons in some weird order? I don't know about cars sometimes these days. I'm not even sure if disconnecting and reconnecting the battery for some reason would help.
Old 01-08-2010, 08:58 AM
Default Re: Window not rolling up for some reason.
Any ideas?
Old 01-08-2010, 09:04 AM
RESIDENT
TypeRfit's Avatar
Most likely it is your switch. Once it gets into the "auto" up and down that portion of the switch might be damaged. I would just try to find or borrow a switch assembly to see if thats the issue
Old 01-08-2010, 12:25 PM
av911's Avatar
You have to reset the auto UP/DOWN procedure. Check your manual.
Old 01-08-2010, 12:28 PM
VroombabyVroom's Avatar
Aye, checking the manual first is always a good idea.
Old 01-08-2010, 03:25 PM
Yes I know, and I did. I just checked it again too. There's nothing in there about reseting it.
Old 01-08-2010, 03:39 PM
av911's Avatar
Look closer..........
eM2tK
Honda Civic (2001 - 2005)
03-14-2011 11:13 PM
dan12288
01-05-2008 06:52 PM
S2K K1DD
Honda S2000
11
03-20-2006 01:47 PM
CNSK
08-19-2005 07:07 AM
david90
05-29-2004 04:22 AM
Quick Reply: Window not rolling up for some reason.
