Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
tire pressure sensor, reset?
Old 10-23-2008, 06:08 AM
z6hatchboy's Avatar
Default tire pressure sensor, reset?
My gf has a 08' civic and her tire was low so she put so air in it, and the light is still on. Im straight eg so i dont know if it has a manual reset or what. I know scion do, but thats a scion. Thanks.
Old 10-23-2008, 06:18 AM
06BlackSi #45's Avatar
Default Re: tire pressure sensor, reset? (z6hatchboy)
The only way to get the light to turn off is make sure pressure is correct on all tires. If the light continues to stay on it will be a sensor problem.
Old 10-23-2008, 08:38 AM
ekb16's Avatar
if its just a Low pressure indicator (!) then just add air up to 34psi in all the tires and drive the car for a bit and it should go back off..if its the TPMS light then there is a mechanical problem wit the sensors or something else
Old 10-23-2008, 09:23 AM
scott0's Avatar
Default Re: (ekb16)
unfortunately the only way to reset the TPMS light is to go to a dealer.
if its only the low tire pressure light that is on make sure the tires have the peoper amount of air. if it stays on it will need to go to a dealer to get the TPMS monitors re calibrated.
Old 10-23-2008, 01:00 PM
av911's Avatar
Default Re: (scott0)
http://www.8thcivic.com/forums....html
Old 10-24-2008, 06:40 PM
Blk06Si's Avatar
Set the tires at 32 PSI. Check for nails in all 4 tires. If there are no nails found and light is still on after you have at least hit 25 mph then you will need to reset the Tire Pressure Monitor Sensor. Bleed the air pressure from the tires to at least 18 psi. It's gotta bleed at least 3 psi within 15 seconds for the sensor to reset itself. Easier and quicker way to reset them is to buy a tire valve remover to let all the air out of the four tires and then refill them. Or you can always take it to a dealer to do what I explained. Hope that helps
Murk13
12-16-2019 07:44 AM
scottfarkus
Honda CR-V & Element
10-08-2015 08:26 AM
Grumpycloud
03-01-2014 07:36 AM
euangincrv
15
01-09-2013 12:38 PM
ricir
30
02-23-2009 07:36 AM
Quick Reply: tire pressure sensor, reset?
