Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Tire Pressure/VSA light stays on?
Old 05-03-2012, 03:13 PM
Murk13's Avatar
Default Tire Pressure/VSA light stays on?
Hey, I've been coming to these forum awhile now looking for answers for problems to my Honda and most of the time I find an answer. Which is a huge help.
I have a 09 Accord EX-L, and 3 days ago I had a flat and had to put on the spare, the car was fine but after a few times driving it, the tire pressure light came on, the VSA light with the '!' beside it, and the brake light, like the emergency brake was on. I checked all the air in the tires, and it was fine, so I figured with the spare, I guess the sensor just thinks its low, and with the spare tire being smaller, making the car a little unbalanced, that's why the VSA and brake light is on.
Well, I put on the new tire, checked all the tires again with the right PSI, and of course shutting the car off to reset the sensors. But, all three lights are still on. Does anyone know why? Is there someway to reset it? Thanks
Old 05-03-2012, 04:02 PM
Salami's Avatar
Default Re: Tire Pressure/VSA light stays on?
Have you driven the car yet?
The light should go off after the new tire is installed on the wheel, the pressure is correct on all 4 wheels with the sensor and the car is driven. IIRC the car needs to be driven a speeds above 19 mph to get all of the sensors to transmit.
The TPMS letters are a MIL. It can come on if the spare is installed or if there is a malfunction of the TPMS.
I have no clue as to why the other lights are on.
Old 05-03-2012, 04:54 PM
Murk13's Avatar
Yes, I have driven the car around all day with the new tire on, I figured it would go off with the new tire on also.
Old 09-03-2019, 09:58 AM
VP1718's Avatar
I have a 2012 Honda Pilot, yesterday I had a flat tire as I was driving, put the spare tire on and drove 100 miles home. As I drove home the VSA and low tire pressure lights were on. Today I changed my tires and the VSA light is still on?
Old 09-04-2019, 08:57 AM
canister's Avatar
Pull the battery plug for 10 min. If after that the VSA light is still on, then use the 9-4 pins trick and read the blink codes. You may have more than one and the first one is the one which really matters.
Old 12-15-2019, 08:48 PM
Eric Thome's Avatar
What's the 4-9 pin trick? Which pins are being referred to the pins on the OBD code reader?
Old 12-16-2019, 07:44 AM
DCFIVER's Avatar
I really wish that nonsense would die. You cant read any codes that way on newer model year Hondas(Im not sure how new,but Id say newer than '06)
Additionally the VSA system probably just needs to be reinitialized. I dont know if it can be done with out a scantool on this model year. Either way you need a scan tool to pull the codes or reinitialize the system.
Frank S
Honda Accord (2013 - 2015)
09-25-2018 10:50 AM
Maxx Martini
07-25-2017 05:28 AM
scottfarkus
Honda CR-V & Element
10-08-2015 08:26 AM
Grumpycloud
03-01-2014 07:36 AM
z6hatchboy
Honda Civic (2006 - 2015)
10-24-2008 06:40 PM
Quick Reply: Tire Pressure/VSA light stays on?
