Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
need advice replacing emblem
Old 09-30-2014, 04:37 PM
dv8omega's Avatar
Default need advice replacing emblem
story:
few years ago, someone backed up into my car, knocked the front emblem off. with the pins inside. parents decide to glue it back on. now it fell off/ or someone took it, idk which.
as of now, pins are stuck inside glued.
how should i go about fixing / replacing this?
Old 09-30-2014, 05:55 PM
97emsedan's Avatar
Default Re: need advice replacing emblem
Is it not bolted to the grill from behind? See if there are a couple of small hex nuts on those threads.
Old 09-30-2014, 06:10 PM
vtecnique69's Avatar
if that doesnt work use a very small drill bit and drill them out. About halfway through they should just fall out the back.
Old 09-30-2014, 06:14 PM
dv8omega's Avatar
drill front the front or the back?
Old 10-01-2014, 04:01 PM
97emsedan's Avatar
The front
Old 10-05-2014, 07:04 PM
The front
what he said.
use a drill bit that is slightly smaller than the pins themselves - 1-2 steps down.
Old 10-21-2014, 04:28 PM
devins701's Avatar
When I switched out my emblems for type r the pins didn't line up so I just broke them off and used 3m double sided tape, didn't fall off for 2 years before selling the car.
fightingirish61
Paint and Body
02-05-2014 06:08 PM
Rudaluda
Paint and Body
03-10-2009 01:34 PM
Squallie
73
11-12-2005 04:59 PM
Ca$h
Welding / Fabrication
01-13-2005 02:22 PM
Steve
05-14-2001 01:17 PM
Quick Reply: need advice replacing emblem
