Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
honda civic 2008 car vibrate at stops and CEL P0497
Old 12-12-2013, 07:26 PM
civicEX1995's Avatar
Default honda civic 2008 car vibrate at stops and CEL P0497
Hey guys.. I have a little bad idle with my civic.. I felt it vibrates when it is on stops.. I felt vibration on the steering wheel And the idle is around 600 rpm.. My car is stock. No modes on it, changed air filter, and sparks plugs with a new ones. It has a Cel P0497... I also change the gas cap. Any idea of where I can star, can that CEL be the culprit of vibrate problems?
Old 12-19-2013, 12:46 PM
Default Re: honda civic 2008 car vibrate at stops and CEL P0497
BUMP!
Old 12-19-2013, 09:11 PM
lazlong's Avatar
You need to take a vacuum gauge to the EVAP purge valve first. If it holds vacuum then one of the other valves is bad or there is a bad wire/connection. If it doesn't hold vacuum then the purge valve is bad.
Old 01-05-2014, 06:30 AM
Thx for replay..
Is the Evap purge valve on the throttle?
Whe u said the other valve were are those?
Old 01-06-2014, 02:08 PM
lazlong's Avatar
Yes, it's on the throttlebody
There's a couple of valves around the gas tank
Old 01-07-2014, 05:36 AM
thx for the replay.. yesterday i was using Torque with an obd2 bluetooth scanner and i noticed that Evap Vapour pressure was giving negative numbers
moving around 13.2, -13.2, -26.3, -55.6 and even -110.. almost all the time stay in -13.2 or 13.2 are these value correct? or my pressure sensor is bad?
Old 01-19-2014, 03:09 PM
bump..!!, any body cant helpme?
Old 01-20-2014, 02:49 AM
Jjbaehr's Avatar
Check the passenger side engine mount, if the aluminum bracket is sitting down on the mount it's shot and needs replacing.
Old 01-20-2014, 02:51 AM
Jjbaehr's Avatar
Old 01-20-2014, 02:53 AM
Jjbaehr's Avatar
This is a example of a good mount, if those arrows were touching the mount needs replacement.
ftrms
05-01-2010 11:00 AM
djtony5
09-09-2005 06:55 AM
Ricey McRicerton
03-19-2004 09:11 AM
onyx00
04-30-2003 05:51 AM
Quick Reply: honda civic 2008 car vibrate at stops and CEL P0497
