Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Buying new shocks/ struts- Rockauto
Old 04-02-2016, 05:01 PM
jokerstone's Avatar
Default Buying new shocks/ struts- Rockauto
HI there
I am looking at purchasing Monroe OE spectrum shocks and struts for my 2007 Honda civic sedan. On the Rockauto site it also lists a Stut Mount and Strut Bellow. I am replacing 2 OEM struts and OEM shocks that are blown. Has anyone ordered this particular brand of shock and strut and did you buy the bellow and the mount? Are the necessary or can the oem ones be used?
2007 HONDA CIVIC 1.8L L4 Suspension Parts | RockAuto
Thank you
Old 04-03-2016, 02:10 AM
holmesnmanny's Avatar
Default Re: Buying new shocks/ struts- Rockauto
How did you determine your existing shocks are bad ? KYB is the manufacturer of struts for our cars and it's likely yours won't be bad until atleast 200k. Save your money and buy some sway bar links and bushings for the front and rear, assuming they haven't been changed yet on your car.
Old 04-03-2016, 01:41 PM
jokerstone's Avatar
I took it in to get an oil change and they did one of those 21 point checks and said that the shocks and struts were blown. The ride is not smooth and the suspension clunks alot when going over bumps etc. Car has 235000 kms (Canadian vehicle) It's also a DX 1.8L, did they come with sway bars in the front and rear?
Old 04-03-2016, 03:04 PM
I'm not going to say its impossible but it's a bit hard to believe unless it has aftermarket struts. Be that as it may, keep in mind there are rebates available for KYB shocks and struts. The clunking you hear is likely more related to the sway bar bushings and sway bar links being bad.
They are fairly cheap priced from Honda.
REAR LOWER ARM for 2008 Honda CIVIC SEDAN
http://www.hondapartscheap.com/auto-...t/knuckle-scat
Old 04-04-2016, 02:21 PM
DaveSi677's Avatar
With that sort of mileage and the way the Canadian roads are they could fairly easily be blown.
Are you replacing just the shocks or the springs also? I would probably go with the KYB route if I had to go that direction also... Don't know exactly what area you are in but make sure you get them from a reputable shop that can warranty them and the work!
Old 04-04-2016, 04:58 PM
97emsedan's Avatar
Good call, DaveSi677, Canadian roads are crap most of the time and at 235K kms those OE suspension parts have lived their life. Check the sway bar end links and bushings for certain, but if not sure, might just be best to replace the whole match, and be certain.
Of course, get a reputable shop with trained, certified techs doing the work and get a good solid warranty.
Old 04-05-2016, 06:06 AM
DaveSi677's Avatar
Exactly!
Also take a look at your ball joints, inner and outer tie rods and bushings while you are at it... it would be about that time to be thinking of all that as they would be pretty close to end of life!
Old 04-07-2016, 04:40 AM
W95 gives me a hard-on
foumer's Avatar
Stay away from Monroe shocks, pure garbage. Get some Kyb.
Old 04-07-2016, 01:18 PM
DaveSi677's Avatar
ya the quickstrut from Monroe is pure garbage.
kyb or even better Koni gets my vote!
George Allender
08-11-2014 01:25 PM
crx1009
04-15-2006 06:35 AM
aleks77
06-02-2005 08:54 PM
Bryan-95prelude
11-08-2004 05:52 AM
osuPrelude
12-28-2002 09:02 AM
Quick Reply: Buying new shocks/ struts- Rockauto
