Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Brake Caliper Slide Pins..
Old 10-10-2014, 07:32 PM
kevinmcc2's Avatar
Default Brake Caliper Slide Pins..
Question for you guys.. I am in the middle of a brake job for my Civic Si and noticed for both the front and rear calipers there is a grooved and smooth caliper slide pin..?
Well, I did not notice until I had everything torn apart and cleaned and when I started reassembly I never took note on which pin goes in the top and bottom?
So, for the front caliper does the grooved pin go in the top or bottom hole?
For the rear caliper does the grooved pin go in the top or bottom hole?
Thanks guys.
Old 10-11-2014, 08:05 AM
back2boostin's Avatar
Default Re: Brake Caliper Slide Pins..
Im looking up at the parts blow up and i can only see that one pin has a plastic washer type thing on the end of one of the pins....Ill assume that it is 06/11?
Let me know
Edit... Groved pin goes on the bottom and the smooth one on top...
Old 10-11-2014, 08:13 AM
Global Moderator
tech8's Avatar
For both front and back calipers, the slide pin with the taper/groove goes on the bottom.
Old 10-13-2014, 05:59 PM
kevinmcc2's Avatar
Thanks guys, may I ask why they are different and what effect it would have if they were reversed?
Old 10-14-2014, 03:39 PM
vtecnique69's Avatar
the same thing happened to me when i did my brakes about a year and a half ago. I got them mixed up and had to switch them around the next day.
I was told that if left alone, eventually the pins would lock up the caliper after some amount of time, causing it not to slide properly, and drag the pads on the rotor.
Old 11-07-2015, 04:19 PM
AmandaMeyer's Avatar
so what does the g stand for on caliper?
Old 11-09-2015, 11:49 AM
DaveSi677's Avatar
This guys knows what he is talking about
Old 05-06-2023, 11:31 PM
honda699021's Avatar
Thanks guys.
Crispypata
Suspension & Brakes
01-15-2017 05:55 AM
AtoZ
10-26-2009 08:16 AM
redman223
05-22-2007 08:36 PM
djay86
03-25-2003 02:45 PM
Type-R 940
03-20-2002 10:51 AM
Quick Reply: Brake Caliper Slide Pins..
