***OFFICIAL 8th Gen General Discussion/Rant/INTRODUCTIONS Thread***
#6226
Re: ***OFFICIAL 8th Gen General Discussion/Rant/INTRODUCTIONS Thread***
Hello, my name is Greg and I've got a 2005 civic hx that i bought used and could use some help with a few issues.
#6227
Hi,
My name is Khiri from the Western Massachusetts area. I recently purchased a 2010 si in May. So this is my introduction post and i also already need a clutch so i was hoping for suggestions. I was looking at the basic OEM Exedy clutch that Advanced Auto Parts sell for like $350. Would that be a suitable clutch for my si? One of my friends suggested that i get a stage 2 clutch, but i feel like they're just more of a pain in the **** as daily driver. Any feedback is greatly appreciated.
#6229
Brand New
For a stock Si, I'd say Honda OE or equivalent unless you plan on modifying beyond the usual bolt-ons.
#6231
me?
#6232
My 2007 Si I bought from my factory trained mechanic friend already had the clutch pedal replaced due to the competition clutch stage 2 pressure plate and clutch disk. I've gotten used to the stiffer feel and daily driving isn't too bad but I still need to swap the push rod from my MC and put it onto the em1 SiR MC I bought. I've read it's a better upgrade that isn't so harsh on the clutch pedal over the Hybrid Racing MC.
Really though, sticking to the Exedy Stage 1 (OEM equivalent) clutch kit will give you solid daily driving and be easier on all your components.
Do a little google searching on MC upgrade and also on clutch pedal reinforcement for 2006-2011 Honda Civic Si and you will likely come across a fair amount of information about all of this.
The other upgrade for these Si's besides Hondata Flash Pro is the Hybrid Racing Timing Chain Tensioner. It's my understanding it's a necessity if you upgrade your cams, valve springs and retainers. I've been thinking about doing the tensioner anyway even though the motor itself is still stock just for the peace of mind of a superior designed tensioner.
#6233
I'm not sure if anyone else has run anything other than Honda MTF in their gear box. It would be interesting to see some feedback.
Today I drained out the Honda MTF from my gear box and I added half a tube of Molyslip Manual Transmission Additive (molybdenum) and GM Synchromesh Friction Modified.
The shifting is much smoother even in high rpm (8000+) shifts. I'm curious to know if the molybdenum is helpful for carbon synchros like it is for metal (brass, steel, aluminum, etc).
I would use Torco MTF but getting it here is a bit expensive and time consuming. I've had great success with GM Synchromesh Friction Modified with Molyslip manual additive but usually in the older manual trannies with brass synchros. Also I can get GM's fluid at any GM dealership so access is easy and quick.
#6234
Im new to the forums, and I apologize if this is in the wrong location....But does anyone know where I can get a badgeless grille for a 09 civic sedan? Ive seen a couple pretty rad ones for the coupe, but not having any luck with the Sedan.Anyone have on on their Sedan..would dig seeing what youve got. Thanks, and again, apologies if this is in the wrong spot.
#6235
Hi,
Try checking out rockauto.com see if they have a clutch for you and if they do, I am pretty sure it'll be at a decent price. You may also want to consider a new flywheel or having your current one resurfaced.
#6236
Fuckkkkkkkkkkkkk
first the wheel hubs were rusted into the brake drum solid.
Now im trying to replace the auto tensioner and the waterr pump pulley bolts are ******* me over
Fuckkkkkkkkkkkkkk
next time i buy old honda that has a FAQ thread lol
Fuckkkkkkkkkkkkkk
#6237
I'm not Rick!
for 2007 Fa5.
Mugen RR front (bumper/grill only)
or.
FD2 front? (bumper/grill/headlights/headlight brackets/fenders/hood)
def don't want 09+ front. looks like a kia
or.
#6238
So, I recently just bought my very own 06 Civic ex coupe and I absolutely love it! It's very clean and all stock which is perfectly fine for right now but I was looking for any&all input or advice on what I can do to tune it up a bit, maybe put a little pep in her step, and help it to just drive better all around without going all out with turbo and stuff. It's definitely something I may like to do in the future but for right now I was just trying to give it a little love and looking for some direction on where to start!? I'm also looking for some ideas on interior, nothing over the top but everything is beige and I was looking to add some color to it or should I leave it as is? I was thinking maybe black floor mats or something but wanted to get some opinions!?
#6239
Re: ***One & ONLY Official 8th Gen General Discussion/Rant/Intro Thread***
Where'd ya hear that AZ licenses expire at age 65? Not that I know of.....
#6241
Hey Guys, I was just thinking about something and I wasn't sure so I came to my favorite forum to ask this: So I have been wondering "If I were to get XK Glow RGB LED Bulbs for my 8th Gen Civic would the RGB lights still work as DRL's during the day
#6242
Since it is an Ex Coupe one thing I would recommend if you have the money go with skunk 2 Exhaust or skunk2 muffler would be the cheaper route
or maybe even a cold air intake @Civic-chick06
#6243
So I bought a 2011 si coupe about 2 months ago as my new daily, the car is bone stock and definitely the best upgrade from my 04 ex. I have been noticing that sometimes when I change from 2nd gear to 3rd sometimes it pops right back out to neutral. Is it me not shifting properly or it's a common issue? This happened about 4-5 times since I got the car. Also wanted to see if you guys recommend me changing the transmission oil, my car is at 84k. Thank you guys in advance.
#6244
I have problem with my Honda civic 8th gen 2009 year . Somebody crashed in my driver door and and i bounced to some metal thing with passanger side door. At first the engine went on for a second after crash and then died and have never started after that. All the lights go on but the dash and headlight start twinkling when i try to start it. Engine didnt get hit , wheels look normal and i dont know what it could be.
#6246
Looking at a buying a 2007 civic si car was swapped to a k20z3 person I plan on purchasing the car says it has forged internals and a bigger cam he claims 270hp didn’t specify at crank or the wheels but either way is this a realistic number for all motor if he is meaning to the wheels?
#6247
Hello fellow Honda enthusiast, I’m new, have an 08 civic that I’ve been working on, a few light mods, some basic maintenance and driving it daily so far. Looking forward to learning a lot and building some cool rides.
#6249
Hi, new to the forum. Interested in learning more about what people are doing on their Hondas and how to perform repairs.
Dogginator
09-11-2008 08:16 PM
epeen
03-23-2007 05:56 AM
