Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Sunroof leak-may be seal
Old 09-25-2009, 02:51 PM
New User
moonakis's Avatar
Default Sunroof leak-may be seal
I have a 2001 Honda Civic w/leaking sunroof. Had the drain lines blown out, but still leaks. There is a tear in the seal in front, so it appears to be the culprit. Any advice on replacing the seal? Honda dealership is saying the whole sunroof needs replacing as it is attached to the glass. Does anyone know if this tear can just be repaired (glued or other)? Appreciate ANY help.
Old 09-25-2009, 03:34 PM
eviee1973's Avatar
Default Re: Sunroof leak-may be seal
for a cheap may or may not help fix, try applying some black weatherstrip adhesive, or silicone sealant to the felt seal on the glass, or on the roof, allow time to cure.
Old 09-26-2009, 08:46 AM
New User
moonakis's Avatar
Thanks, but now after a few days of pouring water all over the car, find that it is the windshield seal. Had the windshield replaced close to a year ago, thought the leak was the sunroof...live and learn. I guess now I don't have any warranty for the windshield install. Anyone have advise on do it yourself windshield seal fixes? Guess I may need to just face the fact I have to pay a windshield installer to fix it.
Old 09-26-2009, 04:36 PM
eviee1973's Avatar
Check for any warranty from your windshield installer, national chains may have one. Have you isolated the leak, top, side, bottom?. Could try silicone or weatherstrip adhesive to patch over the leaking area. Windshields use urethane to hold the glass into place, this helps to provide structural integrity between the laminated windshiled and the body. Only met one guy who was good at removing windshields intact, so would recommend having a professional attempt to remove the glass, if that approach is being used. Are you in a high temperature area, or one with seasons?
Old 09-29-2009, 04:17 AM
New User
moonakis's Avatar
Thanks for your information and suggestions. Unfortunately the install was farmed out to an individual by our mechanic. We are going back there now to see if they will warranty the install. I believe the individual who installed is out of business now, so that may be a problem. The leak is at the top and seems to go under the seal, so hopefully we can just get that "glued" down. I live in the Atlanta area, so we do have high temperatures, but also have seasons.
Old 10-03-2009, 03:21 PM
gordonshumway's Avatar
ive had two leaky cars in the past 1. over passenger door 2. passenger side top of the windshield and both times ive used roofers culk(tar in a culk tube) it just comes in black though. it worked great for me there was no leaks after i applied it
crex46
10-16-2022 05:38 PM
lynn.eppard
04-04-2018 01:50 PM
zhunterzz
08-06-2013 07:42 PM
lucky13AP2
Honda S2000
13
06-28-2006 06:39 PM
iHATEspeedbumps.
Honda S2000
10
02-28-2006 12:03 PM
Quick Reply: Sunroof leak-may be seal
