Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
overflow hose keeps popping off
Old 03-29-2012, 03:45 PM
chawski's Avatar
Default overflow hose keeps popping off
So some brief history...recently replaced radiator, 2 main radiator hoses, waterpump, headgasket and machined the head. I am now having a problem that in warm weather, the radiator overflow hose keeps getting forced off the radiator next to the cap. There is no clamp on this hose, but as far as I know, there is no reason there should be any pressure on this hose, so the clamp shouldnt be necessary. Any ideas what could be causing this? its the same thing that was happening when my HG was blown, but thats obviously not the case anymore? Also, can anyone confirm there should not be a clamp on this hose? again its the hose directly to the right of the radiator cap that goes to the overflow bottle
thanks
Old 03-29-2012, 05:15 PM
shiroun's Avatar
Default Re: overflow hose keeps popping off
Dude.
Just put a freaking clamp on it. Problem solved.
Also it might be overstretched.
CLAMP IT.
Old 03-29-2012, 05:25 PM
lazlong's Avatar
Just to be certain test the coolant for exhaust gases.
Old 03-30-2012, 08:13 AM
chawski's Avatar
Originally Posted by shiroun
Dude.
CLAMP IT.
Yes, I realize its that simple, but dont want to put a band-aid on it. I was asking if there is any logical reason for the pressure buildup. Havnt checked for exhaust gasses, but again, the HG has like 400 miles on it. I would be very surprised if that was the issue. will check it though, thanks
Old 01-01-2014, 08:46 AM
bgmiller7's Avatar
chawski, I know this post is old, but did you ever figure out what was causing the hose to pop off?
I am having the same problem (which I found only after my car has been overheating like crazy). The only thing I can find is a weird coupler-type part in the overflow line, about half way between the tank and radiator. Two hoses connected by this coupler. The coupler looks like it is very restrictive to the flow of the coolant. I'm not sure if this is stock, or if a previous owner put it in.
Thoughts?
Old 01-01-2014, 02:20 PM
Almighty-Si's Avatar
My guess is a bad thermostat. If you have indeed overheated the car, look into getting some money together for a headgasket and cylinder head machining.
PatrickGSR94
08-19-2008 03:48 AM
aziaticvang
02-01-2008 09:34 AM
Ritchie
07-02-2007 08:22 PM
wannakno
Acura TL, RL & ZDX
09-15-2004 06:48 PM
accorddx
04-28-2004 09:38 PM
Quick Reply: overflow hose keeps popping off
