Squeaky bushing front right side?
it's the stock suspension that squeaks it's definitely coming from the right side on the front. i think i need to change the lower control arm bushings and i'll be able to get it on a lift when i do it so it shouldn't be too hard.
what do you guys think?
Re: Squeaky bushing front right side?
Lift the front end up, take a crowbar to the control arm and see how much movement you have. If the whole thing moves the bushing is bad.
as far as replacing it, you would need to buy a new control arm or poly inserts. The bushings are pressed in and would need to be drilled/pressed out or burned out.
Also check your endlinks and swaybar bushings.
sshiny007
20
10-28-2009 06:49 AM
