Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Can I use a 03 Civic D17A1 engine with no EGR Valve in a 05 Civic LX with EGR Valve?
Old 09-26-2016, 08:32 AM
PowerPCME's Avatar
Default Can I use a 03 Civic D17A1 engine with no EGR Valve in a 05 Civic LX with EGR Valve?
I currently have a 05 2-door civic LX with the D17A1 engine and it has a hole in it so i'm looking everywhere for an engine. I've found one on craigslist but its from an 03 civic and it doesn't have an EGR valve. I'm wondering if I could just use my EGR valve with or if i flat out am not able to install it on that engine.
Old 09-26-2016, 08:04 PM
Sanji
toyomatt84's Avatar
Default Re: Can I use a 03 Civic D17A1 engine with no EGR Valve in a 05 Civic LX with EGR Val
Just as an FYI, most states will deem that an illegal swap because the engine is older then the chassis.
Old 09-27-2016, 04:18 AM
lazlong's Avatar
It may run right but I doubt it because it'll be constantly looking for the EGR... and no way will it pass emissions.
Nationwide salvage listings: Car-Part.com--Used Auto Parts Market
Old 09-28-2016, 03:38 PM
Vtec04's Avatar
I did it. Swap the water outlet to the one with EGR and change the metal intake manifold gasket to one with EGR ports and it works fine. Just be sure that putting an older engine than the car in is legal where you live. Also you will need to swap the O2 sensors because the 01-03 is narrow band and 04-05 is wide band. Best of luck man.
buddah51au
09-02-2014 09:37 PM
hmtcrxsir
11-17-2006 07:15 AM
petty$rep
11-10-2006 08:59 PM
RCautoworks
08-31-2005 10:17 PM
Quick Reply: Can I use a 03 Civic D17A1 engine with no EGR Valve in a 05 Civic LX with EGR Valve?
