2003 Honda Civic EX P0300, P0302, P0301, P0303
Any help would be greatly appreciated!
Year: 2003
Make: Honda
Model: Civic EX, manual transmission
Engine: 1.7L sedan 4 Cyl ,
Mileage: 58,000
Stored:
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0300 Random Misfire Detected
Year: 2003
Make: Honda
Mileage: 58,000
Stored:
Re: 2003 Honda Civic EX P0300, P0302, P0301, P0303
Is it overheating any? And you could check your spark plugs for cylinders 1-3 or try switching one of those 3 coils to cylinder 4 to check the coils.
i had a similar issue and fixed it with some cleaner called seafoam. u can buy this at a local aoutosupply store. suck up the liquid through the pcv. i havnt experinced any problems since.
Usually when the PCM stores a "random misfire" code along with cylinder specific codes it's ignition related. Have you replaced your spark plugs? They're due for changing on that model at 110k. If you have more than that on it I would change them. I would only use the NGK factory plugs. They're expensive but it's worth it in the long run. You also may have a failed ignition coil, especially if the spark plugs have significant mileage on them. If it's consistently misfiring under all running condtions, try unplugging each coil pack individually. You're wanting to see if when you unplug a coil pack if the engine runs any rougher or doesn't change at all. If the engine doesn't run any worse with a coil pack unplugged then that is the problem coil pack.
Hey bro I had the exact same problem w my 02 ep3 , I even got the same codes u have exact the problem is the camshaft it self I can bet 100 bucks the lobes are worn and grinded down and im sure tje rockers are no good as well.... Check the cam shaft this was a big problem in 02-03 civics especially si model.honda fixed the poor designed camshaft problem in late 03....hope this helps buddy
Does your gas gauge seem to move around alot, like taking turns and hitting bumps? I just thinking this may be fuel pump related, the plastic shell that houses the pump tends to come apart. Thus the pump kinda just flops around and could starve the engine of fuel. Just a thought.
I just had the exact same problem and like hondarsr I fixed that and the coilpacks and no more problem. oh and I got a 02 civic ex
Yuen001
Honda Civic (2001 - 2005)
35
02-20-2020 11:46 AM
Pudnite
02-11-2018 04:46 PM
Jvega1691
03-25-2017 10:24 AM
accord boy
01-30-2008 04:37 PM
